CLT placement
Moderator: Tom Notch
Dale M.
Re: CLT placement
Post by Dale M. » Sun Sep 11, 2011 5:05 pm
Paul H wrote:Image
This is our sensor and has a 0-300 deg C range can be screwed to a top fin under the shrouds or
just on one of the tin screws as shown.
Like to know more about this!
Who, what , where, how much...
Dale
MarioVelotta
Re: CLT placement
Post by MarioVelotta » Sat Sep 17, 2011 1:51 am
I have done something similar, haven't been able to test it yet.
http://www.shoptalkforums.com/viewtopic ... t#p1053587
Mario@thedubshop.net
2276 Turbo - 92 Octane
11.537 @ 115.74mph - 15psi
1600 S.C. - 92 Octane
15.47 @ 83mph - 13psi
1600 NA ITB - 18sec :lol:
kuleinc
Re: CLT placement
Post by kuleinc » Tue Nov 22, 2011 11:59 pm
This is very interesting, can't wait to see how your home made one works, I may do the same...
1995 BMW 318ti with M3 Motor (Mine)
1994 BMW 325i Sedan (Hers)
1968 Baywindow Camper (Parts Bus)
1971 Westy Baywindow (EFI project...)
My build thread: viewtopic.php?f=14&t=137593
panel
Re: CLT placement
Post by panel » Sat Jun 09, 2012 7:24 pm
Subaru JDM EJ20 Turbo bus
MarioVelotta
Re: CLT placement
Post by MarioVelotta » Sat Jun 09, 2012 11:31 pm
I like that!
sassmatt72
Re: CLT placement
Post by sassmatt72 » Thu Jun 21, 2012 7:51 pm
what epoxy do you use to sink a thermistor into one of those lugs? & where to get it? thanks, matt
MarioVelotta
Re: CLT placement
Post by MarioVelotta » Thu Jun 21, 2012 9:58 pm
I used JB weld and I put the Thermistor in very thin heat shrink first so it didn't short out.
sassmatt72
Re: CLT placement
Post by sassmatt72 » Sat Jun 23, 2012 9:51 am
thanks Mario....matt
Paul H
Re: CLT placement
Post by Paul H » Sun Jun 24, 2012 2:14 pm
Dale M. wrote:
Paul H wrote:Image
Dale
That is a 0-300deg C sensor.
Most engine temp sensors only go to 150C so no good for detecting and dealing with overheat conditions in the VW aircooled.
Since they are expensive and several end users decided to use them as grounding wires :roll:
we now use either the PLX cht thermocouple setup or for the cheap ass route just a M10 regular air temp sensor screwed to the tin pointing at the fins-works just fine
Steve Arndt
Re: CLT placement
Post by Steve Arndt » Sun Jun 24, 2012 2:42 pm
Thermistor is fine for warmup.
Thermocouple is used by zero OEMs, so follow their r&d lead.
Paul H
Re: CLT placement
Post by Paul H » Sun Jun 24, 2012 5:29 pm
Steve Arndt wrote:Thermistor is fine for warmup.
OEM's are usually cheap baztards and have no real need to measure and monitor temp above 150c
so will stay away from the extra complexity and cost of thermocouple circuitry.
Of course thermocouples are widely used throughout industry/aerospace where greater temperature range and accuracy
are needed.
I'd like to see someone measure EGT with a thermistor :lol:
Steve Arndt
Re: CLT placement
Post by Steve Arndt » Sun Jun 24, 2012 6:41 pm
So you do closed loop EGT? Hmmm. People need to get their cars running, not worry about aerospace. Ever seen a shuttle launch delayed because of a bad TC reading? :)
Anyway, don't make this complicated.
Steve
Paul H
Re: CLT placement
Post by Paul H » Sun Jun 24, 2012 7:01 pm
It might be complicated for you to understand but the guy asked a question and I answered it.
No one asked you to butt in with your OEM R+D and space shuttle BS
OK Pumpkin :wink:
MarioVelotta
Re: CLT placement
Post by MarioVelotta » Sun Jun 24, 2012 8:00 pm
I will use the most accurate sensors I can afford regardless if the OEM's use them or not. This is my motor not theirs. The motors they test in the R&D Dyno room are TC'ed up the yang. My motor is a one off so I consider it R&D, it needs to be monitored the best I can afford.
supaninja
Re: CLT placement
Post by supaninja » Sun Jun 24, 2012 8:45 pm
Panel- I like that, hit me with the info.
viewtopic.php?f=14&t=140387
