For better or worse, I've taken the plunge.
This is the 30 Cavity Junction system from EFI Connection ( https://www.eficonnection.com/eficonnec ... fault.aspx ) Part numbers 100-00416 and 100-00417.
Pardon the raw links. For some reason I'm getting "It was not possible to determine the dimensions of the image." when I wrap them in the img tag.
http://www.maxwelton2k.net/ghia/Engine/ ... 211018.jpg
http://www.maxwelton2k.net/ghia/Engine/ ... 211138.jpg
http://www.maxwelton2k.net/ghia/Engine/ ... 211229.jpg
http://www.maxwelton2k.net/ghia/Engine/ ... 211249.jpg
http://www.maxwelton2k.net/ghia/Engine/ ... 211345.jpg
http://www.maxwelton2k.net/ghia/Engine/ ... 212114.jpg
http://www.maxwelton2k.net/ghia/Engine/ ... 223851.jpg
The terminals are Delphi Metri-Pack 280s and 480s. And I neglected to get the female connectors. I'm a duffus.
Max
Engine wires connector + SOME MORE QUESTIONS
- Max Welton
- raygreenwood
Re: Engine wires connector + SOME MORE QUESTIONS
Yep....great plug housings, seals and good male pins. Just keep an eye on things around the 60k miles and 6 years period if you drive it regularly.
That housing design takes a single cantilever...no springs at all....type terminal. GM had eons of troubles sprinkled with numerous recalls with that system as it aged. However if you know thats an issue you can catch and correct it when the anomalies show up.
Ray
Ray
