pic's of megasquirt mounted
Moderator: Tom Notch
miniman82
Post by miniman82 » Mon Jul 28, 2008 9:02 pm
It's more of a headache to build that cable than it is to buy it, trust me. :wink: DIY Autotune is tops with MS stuff; service, quality and price are A1 in my book.
BOB JOHNS
Post by BOB JOHNS » Mon Jul 28, 2008 9:40 pm
they are no doubt real good at what they do ..... i am just tryn to this on a budget .... just a had a boy he is almost 3 months old ... but i might just send it to them ......
MarioVelotta
Post by MarioVelotta » Tue Jul 29, 2008 11:42 pm
Oic, all you need as a little 45 watt pencil solder iron. It will take an hour or so and if you have a vise that will make it go pretty quick. When I made mine I just did every pin. I'm really glad I did that so I can use all the spare pins without messing with the harness again.
Mario@thedubshop.net
2276 Turbo - 92 Octane
11.537 @ 115.74mph - 15psi
1600 S.C. - 92 Octane
15.47 @ 83mph - 13psi
1600 NA ITB - 18sec :lol:
BOB JOHNS
Post by BOB JOHNS » Wed Jul 30, 2008 5:22 pm
I been coolecting the piece's .. need manafolds, intake, ehaust and last but not least a hybrid t3/t4ballbearing turbo,blow off valve..... :twisted: :twisted: ineed to make a shorter cable and then and with the left over iam going to make a new loom from the relay box to the appriot places.. :lol: going to be sweet...
[/img]Image
MinamiKotaro
Post by MinamiKotaro » Wed Jul 30, 2008 8:17 pm
George II, my MS1v3.57.
'67 Beetle, 2276
MS-1 v3.57
MarioVelotta
Post by MarioVelotta » Wed Jul 30, 2008 10:08 pm
When are you going to mke use of that sweet sweet db15 plug :lol:
BOB JOHNS
Post by BOB JOHNS » Thu Jul 31, 2008 4:57 pm
hopefully soon i will be cutting that sweet loom ... Iam going to make a 12 in cable and then use the rest for the loom from the relay box...
scotlandstu
Post by scotlandstu » Wed Aug 20, 2008 3:20 pm
MarioVelotta wrote:Is your VR sensor 90* to the trigger wheel? Have you run it that way yet? Curious how well it works.
Have had it running now and it appears to work fine, not seen any more that 2.5K yet as still waiting for my backbox with lamda sensor bung in it so if you reved it the sensor fell off where it was balanced and it dies.... :lol:
panel
Post by panel » Tue Sep 09, 2008 11:18 pm
Mine (is a mess) but mounted under the Westy seat in the back of the bus. I also relocated the battery there years ago to clean up the motor compartment.
Subaru JDM EJ20 Turbo bus
bugsterkafer
Post by bugsterkafer » Mon Sep 15, 2008 5:39 am
Here is mine, mounted behind the rear seats of my bug, not so messy since the pic :lol:
MarioVelotta
Re: pic's of megasquirt mounted
Post by MarioVelotta » Sat Nov 07, 2009 3:24 pm
Bump
WickedWagens
Post by WickedWagens » Sun Nov 08, 2009 2:12 am
Here is mine so far. I made a rack to hold the ecu, relay board, and wideband. Everything is rubber mounted and then the rack is rubber mounted also.
MinamiKotaro
Re:
Post by MinamiKotaro » Sun Nov 08, 2009 8:04 pm
panel wrote:Mine (is a mess) but mounted under the Westy seat in the back of the bus. I also relocated the battery there years ago to clean up the motor compartment.
Holy crap! I thought mine was bad. :lol:
miniman82
Post by miniman82 » Sun Nov 08, 2009 11:52 pm
That's nothing, have you seen mine on page 1? :shock:
miniman82
Post by miniman82 » Sun Nov 08, 2009 11:54 pm
It's a lot neater looking now, I had some work done to it.
