pic's of megasquirt mounted
Moderator: Tom Notch
MarioVelotta
Post by MarioVelotta » Fri Jul 25, 2008 12:40 am
miniman82 wrote:Crap, deleted while trying! :x
What EGT sensor are you using?
Mario@thedubshop.net
2276 Turbo - 92 Octane
11.537 @ 115.74mph - 15psi
1600 S.C. - 92 Octane
15.47 @ 83mph - 13psi
1600 NA ITB - 18sec :lol:
miniman82
Post by miniman82 » Fri Jul 25, 2008 4:24 am
:shock:
And here I thought no one paid attention to my frankenstien-ien contraptions! Like they say in the ebonic language, YOU DA MAN! :lol:
Link restored, feel free to get rid of the one in your post. :wink:
Umm, I'm not sure I remember where I ordered the EGT probes from, lemme look.....
Ah, here we go: Sensor Connection
Pretty easy to install; just grab the right size drill bit, make a hole, put the compression style fitting and clamp on, and presto! I have one in #2 primary tube as close as I could get it to the flange, and the one you see next to the wideband O2 sensor in the pic. #2 primary usually shows anywhere from 1000*F (cruise, idle), to 1350*F (boost, high load). The one after the turbo never goes above 700*F. I've been meaning to try some header wrap to try and boost temps, and hopefully decrease spool time.
scotlandstu
Post by scotlandstu » Sat Jul 26, 2008 5:54 am
Mine in my latebay, wiring loom in progress. Engine bay relay board from an old peugeot that was getting scrapped...
MarioVelotta
Post by MarioVelotta » Sat Jul 26, 2008 3:10 pm
Is your VR sensor 90* to the trigger wheel? Have you run it that way yet? Curious how well it works.
BOB JOHNS
Post by BOB JOHNS » Sat Jul 26, 2008 9:11 pm
I have not used a soldering iron in a long time but I am guessing your to solder the end when maken the plug? at 700 temp?
scotlandstu
Post by scotlandstu » Sun Jul 27, 2008 8:21 am
MarioVelotta wrote:Is your VR sensor 90* to the trigger wheel? Have you run it that way yet? Curious how well it works.
Yeah it is saw a couple like this when looking through other sites, made making a mount very easy, bit of metal and vice and beat with hammer (my kind of engineering :lol: )
If it doesn't work haven't lost much, but if it does saves me a bit of messing about making a straight on mount. Will let you know....
RonW
Post by RonW » Sun Jul 27, 2008 11:49 am
i ended up locating my ms2 v3.57 and relay board in the glove box area
912R + STi 2.0 Turbo JDM v8
BOB JOHNS
Post by BOB JOHNS » Sun Jul 27, 2008 4:59 pm
what size motor you running ron?
miniman82
Post by miniman82 » Sun Jul 27, 2008 6:11 pm
Um, I'm gonna guess 2270cc, based on his SIGLINE. :wink:
RonW
Post by RonW » Sun Jul 27, 2008 7:50 pm
mini is omnipotent :p
yep, 2270
miniman82
Post by miniman82 » Sun Jul 27, 2008 9:46 pm
Damn, I'm good. 8)
MarioVelotta
Post by MarioVelotta » Mon Jul 28, 2008 12:11 am
BOB JOHNS wrote:I have not used a soldering iron in a long time but I am guessing your to solder the end when maken the plug? at 700 temp?
huh?
miniman82
Post by miniman82 » Mon Jul 28, 2008 1:39 am
Soldering irons are only like 450*F, don't know what would happen if you used 700....probably burn the board. :?
raygreenwood
Post by raygreenwood » Mon Jul 28, 2008 6:55 am
Solder has no place anywhere in EFI or or EGT systems. Its a failure point. Factory got rid of it about 3 decades ago for this reason.
Use proper crimp connectors with a ratecheting factory style compression crimp. Lots of conversation and info on teh subject in these forums. Ray
BOB JOHNS
Post by BOB JOHNS » Mon Jul 28, 2008 8:22 pm
i have to make a end to plug into my ecu to relay board . I bought a IAC Valve Connector, 12' MegaSquirt Wiring Harness ,TPS Connector , Shielded 20 Gauge ,MegaSquirt Relay Board ,GM Closed Element CLT / IAT Sensor,GM Open Element IAT Sensor for 140 bucks ...
i need to make a cable like this Image
