pic's of megasquirt mounted
Moderator: Tom Notch
BOB JOHNS
Post by BOB JOHNS » Tue Jul 15, 2008 5:12 pm
come on guys lets see those pic's ......
miniman82
Post by miniman82 » Tue Jul 15, 2008 9:04 pm
MarioVelotta
Post by MarioVelotta » Thu Jul 17, 2008 10:03 pm
This is an old pic, I have a couple more things there now. I need to take a new pic.
miniman you need to clean that up a little. Do you ever get light headed from fumes :shock:
Mario@thedubshop.net
2276 Turbo - 92 Octane
11.537 @ 115.74mph - 15psi
1600 S.C. - 92 Octane
15.47 @ 83mph - 13psi
1600 NA ITB - 18sec :lol:
miniman82
Post by miniman82 » Fri Jul 18, 2008 12:11 am
I know, it looks like ass! :lol: There's really no fumes that I can tell, it's sealed up pretty tight. If there were, I probably still wouldn't be able to tell, cause I have to have the window down it gets so hot in there. :oops:
panel
Post by panel » Sat Jul 19, 2008 11:00 pm
This is my buddy Devin's in his '66 bug. It was our first MS install and car to get running.
Subaru JDM EJ20 Turbo bus
BOB JOHNS
Post by BOB JOHNS » Sun Jul 20, 2008 5:08 pm
panel wrote:This is my buddy Devin's in his '66 bug. It was our first MS install and car to get running.
kool thats my son's name he is two month's old kool kool...
Jadewombat
Post by Jadewombat » Mon Jul 21, 2008 8:55 am
You guys shouldn't mount these on the floor, you get a water leak and it starts collecting there and you're hosed. I had a CD changer in my Golf under the drivers' seat and the door seal sprung a leak. I was out of town and by the time I got home there was 1" of water there, the CD changer was of course junk after that. Mount it up on a wall somewhere vertically or at least elevate it a few inches.
grelland
Post by grelland » Wed Jul 23, 2008 5:19 pm
Here's a few shots of my installation in my Ghia:
Planning to fire it up this week, if the logistics works out...
Rick_Eberle
Post by Rick_Eberle » Wed Jul 23, 2008 7:26 pm
Mine's in the console...
warp
Post by warp » Thu Jul 24, 2008 2:19 am
raygreenwood
Post by raygreenwood » Thu Jul 24, 2008 8:00 am
You need to put an enclosure on that board in the last picture....but nice work! Ray
panel
Post by panel » Thu Jul 24, 2008 8:30 am
raygreenwood wrote:You need to put an enclosure on that board in the last picture....but nice work! Ray
In all those pics the relay board is exposed Ray. Mine ,Marios etc.
raygreenwood
Post by raygreenwood » Thu Jul 24, 2008 1:03 pm
Ok...a question then....what is the multi-pin connector on the right side of that relay board going to?
If that is in fact going to anywhere in the fuel injection system..and uses the type of unsealed card edge connector it looks like......and if those wires on the top edge of the card goe anywhere into the main EFI loom....and use what looks to screw down clamp connectors.......they should be covered. There are Huuuuuuuge reasons all of the OEM's started out the way you have it...and ended up with full weather tight enclosures.
Even the OEM's have issues still. I'm trouble shooting injection issues right now on no less than three cars, three different makes all within 4 years old....that have systemic high resistance issues....precisley because the manufacturers got careless and left certain power couplings/tabs and ground connectors unsealed by design.
All it takes is driving in humid or corrosion prone areas. On modern systems (even worse than the simpler old ones)...all it takes is surface corrosion on select terminals to create an endless series of recurring faults.
I'm just saying...learn from the mistakes of thousands of others that came before you. Ray
MarioVelotta
Post by MarioVelotta » Thu Jul 24, 2008 4:58 pm
Looks like this thread is off to a good start, lets keep them coming.
When I have a chance to make it out to my buggy I will shoot a couple of pics where the brain will live in it also.
I don't dought the corrosion issue, but I haven't had any issues with it yet... I don't drive mine daily so I guess what it comes down to is that i'm not that worried about it.
Hey Mini, can you resize your pic for us?
miniman82
Post by miniman82 » Thu Jul 24, 2008 10:19 pm
MarioVelotta wrote:Hey Mini, can you resize your pic for us?
Crap, deleted while trying! :x
I can take another?
