I'm glad that I can seal in the MS. The rail doesn't really have an engine compartment so the outside of the box will stay cool but I don't know if the MS will dump more heat into the box than the box can dissipate. If other people have done it with no issues than I should be fine.
Thanks for letting me know that other people have just run a Tee fitting on the top of injectors. I was worried that this would cause some unseen issues. I would much rather deal with plumbing FI hose and the special FI clamps than trying to fabricate a fuel rail.
I will freely admit that I am very cheap but I buy new or put the money down when it makes sense. It is the reason I am springing for the MS2 instead of MS1. You won't see me pulling FI hose out of the junk yard to save some bucks. For something like a FPR or TPS however, I will buy used and I will buy cheap. These are very simple device that have been installed on hundreds of different makes and models. I do however have a healthy fear of the "fleabay knockoffs" that look shiny but fall apart. I'll most likely find a FPR from a Buick turbo regal or a turbo dodge for $10.
Thanks for the TPS link. You are right about the CB TPS not bolting right on as I just got a reply from CB. I don't have access to a lathe but I might be able to create something similar. What ever I come up with will have to be tough enough to handle offroading while easy enough to create with a drill, dremel, and a hammer! You would be surprised at how much can be done with very little tools.
Here are pics for your visual enjoyment. The 'car' is completely street legal but I will always have more fun drifting around dirt corners than I will killing a WRX at a stop light. BTW, this is my first car
