hello all.
hope you can help. I have a 2.0 914 with a broken dipstick tube.
the previous owner has installed a flexible hose as a fix, which sticks out the top of the tinware, but I am not convinced about the length of this....
can anyone tell me how far a 914 dipstick tube sticks up over above the tinware?
Also I have a new tube on order... how do I install this? it seems like a bit of a nightmare to be honest...
thanks,
M
Dipstick tube
Re: Dipstick tube
The simplest fix would be to use a small block chevy V8 tube and dipstick, available at most auto parts stores in either straight or curved flavors for <$15.
This is commonly used in upright conversions, you drill a hole right where the 914 dipstick is, and press in with some green Locktite or JBWeld. The sump plate on the block allows access with a shop vac or such on the inside to vacuum/flush out any metal bits as you drill.
I will try and make a measurement of the stock dipstick tube tomorrow AM if you still decide to extract/replace the original tube.
Re: Dipstick tube
Sorry, I measured a few 914 dipstick tubes the other day. but forgot to reply.
I got just a hair over 6" top of tube to case.
