914 Transmission!
Moderator: Piledriver
Lew
914 Transmission!
Post by Lew » Sun Nov 27, 2011 9:07 pm
What would this be worth? It's been on the ground for several years.... Not mine, owner desperate to sell. :)
Twystd1
Re: 914 Transmission!
Post by Twystd1 » Sun Dec 11, 2011 2:34 am
In Cali. This is considered a core transmission. As NO ONE knows it's internal condition. They are worth between 100 and 300 bucks in SoCal IF you can find a buyer.
I have 5 more of em if you need more cores..... I have purchased many of those for 75 - 100 bucks.
In other areas of the US. Core transmission can be worth more. How much more??? I have no idea.
Clayton
aircooledtechguy
Post by aircooledtechguy » Mon Dec 12, 2011 11:31 am
I agree with Clayton. Around $100-$150 MAX.
Ron Perkins
Post by Ron Perkins » Tue Nov 06, 2012 8:34 pm
What kind of HP can they handle stock.... I've heard 300 hp
Post by Piledriver » Tue Nov 06, 2012 8:43 pm
Ron Perkins wrote:What kind of HP can they handle stock.... I've heard 300 hp
Except for first gear... IIRC rated for 250 ft/lbs torque, but have been used extensively w/V8s on them, it's all about how you ab^^use it.
Some factory racers pushing or exceeding that had external gear oil pump setups to improve reliability and keep temps down, probably a good idea.
It is a Porsche part so as Nate noted, replacement parts are Por$che pricey, although they are far easier to actually work on than VW transmissions.(few>no weird $$pecial tools or jigs)
Ron Perkins
Post by Ron Perkins » Tue Nov 06, 2012 9:10 pm
Understood....if it could break...this guy could do it. Need to learn how to use and not abuse....thanks.
