I have a 914 2.0 engine and a T3/T4 turbo plus a
set of Weber 44's! I was wondering where you could
fine turbo parts for a T4 motor? (tubes, wastegate, etc)
Thanks,
Charlie!
[email protected]
Turbo 914!
Welcome to the forums!
There are numerous examples of various plumbing setups on the forced induction forum to give you some ideas, but the 914 has some slightly different requirements as to plumbing (of course)
That is also the place to look for recommended turbo BOVs etc.
Evill Ed had a beautiful turbo'd 914 that was featured in Excellence magazine 2-3 years ago, if memory serves me right, he used a Bursch or perhaps a Thunderbird "header" and ran the pipe to the turbo up/back the right side... http://community.webshots.com/user/evill914
http://members.rennlist.com/evill/
This has the benefit of being easy and retaining heat/defrost etc.
I'd personally mount the turbo just ahead of the right rear axle.
He used CIS. I am also a HUGE CIS fan. I strongly suggest a CIS-E setup off a ~92ish Passat 16V, computer is completely optional. (What is in the currently wounded but soon to be resurrected Pile) If you still have the factory intake manifolds/plenum, you are ~90% there. MillerFI appears to be no more, but the injector adapters are an easy 30 min job and are retained by the factory hold downs. (unmodified manifolds)
Note a Volvo 2-740 air/air intercooler fits ~perfectly above a 914 motor... Would not be difficult to make sure the fan sucks all its air through it.
(I have 2 in storage )
Re: Turbo 914!
you can't turbo a 914
