Relay location
Relay location
Anyone here got any info on the relay locations 76-914 2.0fi no A/C ?????
- Type 4 Unleashed
Re: Relay location
Which relays you looking for ?68Ghia wrote:Anyone here got any info on the relay locations 76-914 2.0fi no A/C ?????
There are some relays on the relay plate in the enging compartment, behind the drivers seat, it also holds the voltage regulator and the harness from the alternator plugs into it, along with the engine harness.
There also some relays on the other side of the fuse box.
Each headlight motor has a relay under the plastic side cover.
Richard
EMW
EMW
- Type 4 Unleashed
Re: thanks
The fuel pump relay is on the relay board in the engine compartment, there are 4 relay locations, the 1st one to the back of the car to the left of the 10 pin engine loom is the heater blower relay, the next one up to the left a little is the fuel pump relay, next one up to the right is the power relay for the fuel inj, and the 4th is up to the left for rear window defogger on later cars which you may have.68Ghia wrote:I'm looking for the fuel pump relay so I'll start looking this PM w/ the info you gave me. Thanks again
Richard
EMW
EMW
