Hi, this is the deal, I've got a 88 Turbo coupe engine with LA3 ecu Big VAM everything, well the wiring harness was junk, so i found a guy selling a good Merkur harness... I was later told 2 pins needed to be moved, and I had found a website that told what to do, and now I'm read to do this, and I have lost the website or it is no longer there...
Does anyone have a link, or can tell me which 2 pins need to be moved for my Merkur harness to work with my LA3 ECU?
Thanks for any help you may provide.
Wiring harness question, Please read.
www.turboford.org that site should have more than enough info. here too
http://gt350r.stangnet.com/index.html
- N2Otorious
I tryed posting there as well, but for some reason, I'm having trouble logging in. I've cleared cookies, deleted all offline files etc. enter my user, and pass then it says thanks for logging in, hold while you are redirted blah blah blah, then when the screen refreshes to where I was before loggin in, it says I'm not logged in, so I'm not able to log in sucessfully over there at the moment...Anonymous wrote:www.turboford.org that site should have more than enough info. here too
