Harness help
Garey
Harness help
Post by Garey » Sun Sep 03, 2017 2:24 pm
Hi everyone, I have a question for those that have done a wire harness conversion,I have followed directions from you tube busaru,( this guy knows his sht) I'm at the point of testing the harness, I have power to the relays from the battery & power on the ignition side out of the relays butt no clicking sound or power to fans/fuel pump I'm not sure what ground to hook up @ the engine plugs ( this test is on the bench ) can someone chime in with help thanks 1996 2.2
Garey
Re: Harness help
Post by Garey » Sun Sep 03, 2017 2:42 pm
Thanks anyhow, it's very important that when you plug the Ecu in that you flip the little lever to lock it in! DUH...
