Valve lash adjusters
63vwbug
Post by 63vwbug » Sat Nov 26, 2016 12:13 pm
Hello.
I've got a carbed 2.2 subi motor in a vw bug. The motor has about 300 miles since a rebuild. For some reason, I started getting a lot of lifter noise. I removed the valve covers and found 7 (hydraulic) lifters that were loose.
Why would the valve lash adjusters loosen up? As a note, these lifters were reused from another motor. Motor oil pressure was good.
danielzink
Re: Valve lash adjusters
Post by danielzink » Mon Nov 28, 2016 5:38 pm
Did you try removing them and re-pressurizing them ?
65 Notch 2300cc Type4
EJ22 powered Rail
http://www.danielzink.com
63vwbug
Post by 63vwbug » Mon Nov 28, 2016 9:35 pm
I did not try and pump them up again. I was looking for input first before I messed with anything.
Post by Piledriver » Tue Nov 29, 2016 2:21 am
The cams look OK? No wear on the lifters?
They only have a certain amount of lash they can adjust for, might want to hit the manual and see if the specs are any help.
danielzink
Post by danielzink » Wed Nov 30, 2016 9:43 am
63vwbug wrote:I did not try and pump them up again. I was looking for input first before I messed with anything.
HLA Servicing is super easy and simple..
Literally maybe an hour job.
I had a couple pump down on me after the motor sat over the winter. Now I'm a pro at it ! :D
Subaru HLA servicing
1. Pull off Valve Covers
2. Remove the Rocker shaft assembly by removing 10 bolts.
3. Bring the whole assembly over to the bench.
4. Pull each one out with pliers carefully.
5. Submerge each one into oil and pump the check ball with an allen wrench. Then push on the top to push the old oil out. Repeat a few times. Let them fill all up with oil before pulling them out from under the oil
6. Insert them back in and push on the top to feel if they were squishy or not.
7. Put it back in and torque each bolt to 8.7ft pounds.
8. Reinstall the valve cover.
just like this video:
https://www.youtube.com/watch?v=8OVBPnukR4w
EJ22 powered Rail
63vwbug
Post by 63vwbug » Wed Nov 30, 2016 10:05 am
Nice, thank you!
But is there a reason they pumped down? Shouldn't they pump back up with oil pressure? Should I install new ones for $75? The reason I asked this is I have to drop the motor to get to the valves on the left side. A bit of a pain.
