Hi I am redesigning my shroud and need some advice Im enclosing the jeep cherokee rad . The rad dimensions are 27 1/4 inches long and 20.5 inches wide . Question 1 should i mount the slimline fan onto the top of the shroud or mount it right to the rad blowing down towards the ground . My reasoning is at highway speed the cooling surface will be unobstructed by the fan The effective rad cooling surface area is 21 inches long by 19 inches wide the lowest shroud closest to the ground is going to sealed to the rad with 3 inch holes for the hot air to escape.
Any advise would be appreciated thx Al
ej 22 suby in vw split bus underbelly rad design questions
- panel
Re: ej 22 suby in vw split bus underbelly rad design questio
Don't know if this will help ?
http://1979vwconversion.blogspot.ca/201 ... chive.html
http://1979vwconversion.blogspot.ca/201 ... lines.html
