Fan Belt Used on the Subaru Conversions
- mpate
Does anyone know off hand what alternator belt is typically used on the subaru EJ22 engine once all of the pulleys, etc. are removed and not utilized for a VW swap? Thanks for the great advice in this forum.
- Prtexx
Re: Fan Belt Used on the Subaru Conversions
Oreily's #K050275
Steve
67 VW roadster
36 Buick 3 window coupe blown 350
87 Syncro 2.5 Subaru
84 Westy
77 Westy 2.5 5 speed
FB VW Subaru Conversions
67 VW roadster
84 Westy
- mpate
Thanks so much.
- Buggin_74
The actual size of the belt if you don't have access to an Oreilys is 5PK690
1974 Germanlook 1303 Suba-Beetle
Subaru EJ25 Boost R 17", 4 Wheel discs, Topline suspension and A/C
- bad62bug
- surfbeetle
Is that the belt size for just going from the crank pulley to the alternator with the alternator directly above the crank pulley?
