vw 1303 ej207 sti powered porsche g50 gearbox. 350 hp
johan84
Post by johan84 »
hello
i though maybe some of you liked my swap
5 years ago i started with a 1972 vw beetle
the plan was to build a fast beetle with at least 300hp
intercooler intake both windows are moved 15cm about 6 inch inside in the rear
outlet is under the little wing on the back
youtube:
http://youtu.be/-2wilTC5Cs0
http://youtu.be/GrFrrbbncL0
http://youtu.be/fae2gHi20fE
http://youtu.be/L1PKfK_BaWE
car spec:
VW 1303 beetle 1972
engine
2002 subaru wrx sti (bugeye model) ej207 sti engine VF35 turbo
engine is stock
ecu: 2002 sti jdm ecu (i used jdm ecu because no need of immoblizer and keys instead of euro models)
ecu is ecutek remapped to 98 oct fuel and runs around 1,5 bar boost
should have at least 325hp+. it is not been on the dyno yet
rev.limit 7800rpm
i can get 120klm (75mph) in second gear ;)
exhaust:
custom made 3" stainless steel with 2 magnaflow 4" mufflers
i'm driving with DB-killers it is now 2 times 2,25"
but it has no influence on the power or spool up of the turbo
but driving without db killers makes it like a rally car sound
there is a youtube link above
gearbox:
porsche 911(964) G50.03 5 speed gearbox incl shifter
that is modified to custom shifting linkage
clutch adapter kit
KEP: adapter kit
sachs stock 911 pressure plate
and high performance 6 puck kep clutch plate
spec can hold up to +/- 850nm
suspension
front: fk-coil overs
944 hubs and brake discs
porsche boxster brembo calipers
custom made steering arms/rods
custom made stabilizer bars(cupstrebe
rear: 944 suspension arms and brake discs
custom made stabilizer bars(cupstrebe)
red9design uniball system
spax coil overs
wheels/rims: steel rims 16inch rear245/45/16 front215/35/16
pre 65 chrome covers
fenders front fully steel: front widened 2,5cm 1 inch
rear widened 6,5cm 2,5inch
fully roll cage incl doorbars
2 gt3 racing seats
4 point belts
omp steering wheel
2002 sti instrument cluster
boost, oil pressure and oil temp gauges.
and much more
i have to do some little things on the interior
and polish the paint
and i need to make a front splitter
because when doing around 200klm (125mph)
it is getting to search on the road a i need to do little
steering corrections just like in old porsche's
i going to make a splitter in the front to improve this
when it is doing better and i can test it on the autobahn next year
(i'm from holland and live 15klm from the autobahn ;D )
hope you like it
greets
Johan M
holland
RonW
Re: vw 1303 ej207 sti powered porsche g50 gearbox. 325hp+
Post by RonW »
johan,
-wow, great first post :D so cool! i dont think you will have to worry about the G50 holding up!!! impressive.
-i see in the vids and pictures that you are running turbo in stock location but where is you intercooler located?
love to see how you are running your cooling lines. i see you must have modified the upper coolant crossover tube, looks much cleaner exiting that way.
-lets see some pics of your radiator set up as well.
-looks low, im sure you did some clearancing of the oil pan, how did you handle that? dry sump? ;)
great work, hope so hear/see more of your project.
ron
912R + STi 2.0 Turbo JDM v8
johan84
Post by johan84 »
RonW wrote:johan,
-looks low, im sure you did some clearance of the oil pan, how did you handle that? dry sump? ;)
ron
thanks ron
intercooler is placed under the rear window and above the and of the gearbox
out let is under the wing to get the airflow the is coming over the car flowing in he same direction as
the air that is coming through the intercooler so the flow over the car is not disturbing the flow out of the intercooler
i have change the cooling pipe on the engine block to have a shorter circuit
radiator is a wrx turbo oem radiator with oem fan's so the switch on and of by ecu signal just like original
from the radiator place i have only very early pic on the construction
oil sump is oem
the lowest point under my car is the exhaust it is about 11cm
sump is 15cm or so
RonW
Post by RonW »
Very cleaver way of directing the air into the IC.
Have u data logged your intake air temps to see how effective it is?
Did u just flip the cross over tube 180deg?
How did u run ur coolant lines?
I like the shrouding for the rad. How r u directing air in and out?
15cm oil pan height w stock pan is frickin awesome!
Lots of unique and clever ideas. Thanks
johan84
Post by johan84 »
RonW wrote:Very cleaver way of directing the air into the IC.
the cross over tube is in oem position i cut of the pipe and fabricated it on the oder side
coolant lines are under car in 1 on both side of the middle chassis tube
and on come up under the fuel tank and directed to the radiator
intake air for the radiator is through the oem vw oil cooler grille
the are about 2 cm bigger to let a little bit more air in
and the compartment of the spare wheel is gone
the air is flowing underneath the car and in the direction of the openings in the fenders
clearance is not to bad on the oil pan :)
thanks
4agedub
Post by 4agedub »
Some interesting ideas there. I like your intercooler vents.
VW Beetle 1303 EJ20T Subarugears Circuit Racer
VW Beetle 2332cc 200hp N/A Circuit Racer
VW Beetle 1969 2666cc Turbo Road Toy
johan84
Post by johan84 »
4agedub wrote:Some interesting ideas there. I like your intercooler vents.
thanks! :)
rubbachicken
Post by rubbachicken »
i very much like what you did with the the rear window vents, it's nice to see something new, especially when it's done well like that
itawolf
Post by itawolf »
Very nice setup
RET Marine 0317 --with VW on the lobe!!
Lots of iron in the fire
johan84
Post by johan84 »
Made a new vid
Wiht a hd cam
But when i was home again it was on 720p and not on full hd
But still nice to see i think
Next will be on full hd
http://youtu.be/ldYdgGaC22M
It is al most fully done
I bought a kamei spoiler that will be fitted and i have to do an splitter
And then it is 100% ready
Master slacker
Post by Master slacker »
Got any pics of the Subaru gauge cluster install on the dash? I've always thought that would be a neat touch for a conversion build.
johan84
Post by johan84 »
Master slacker wrote:Got any pics of the Subaru gauge cluster install on the dash? I've always thought that would be a neat touch for a conversion build.
just placed a new vid on youtube
a sprint from 0 - 200 klm
there it is in
http://youtu.be/PG10E8_utiI
http://youtu.be/ri5BRdfaQ1s
johan84
Splitter installed for more downforce
Post by johan84 »
Installed a kamei spoiler and made a splitter underneath
For more stable drive at higher speed
Around 180 the car is getting light in the front
When i get enough downforce
I will do a autobahn run soon
ivwshane
Post by ivwshane »
You said, "180" and I nearly poop my pants but then I realized you are talking km not mph:p
johan84
Post by johan84 »
ivwshane wrote:You said, "180" and I nearly poop my pants but then I realized you are talking km not mph:p
yes klm haha :D
