It looks just like this…
So the thing is, I basically grew up with this car. It was my fathers and now it’s mine. It needs a motor badly and I decided to go Subi-power after looking at the cost to build a type 1 engine with Chinese parts scared the crap out of me. And the cost to go type 4 scared me too. So I started researching it and figured out that the Subaru turbo engine needs the Subaru trans with it if you want to handle the horsepower and have an overdrive (75 mph at less than 3,000 rpm, yeah!). This project is currently going to be just an engine and trans swap. There are other things I want to do with the car, but I need to do this a piece at a time due to my budget. In the future I plan to do a pan-off restoration with Mendeola suspension and 944 turbo brakes…but that is sooo not happening now.
So I started collecting parts for this conversion! I was able to work a deal with Todd at Subarugears for what was probably his first and only groupbuy…(major thank you for that Todd! It went super smooth.) So with one of the major part hurdles under my belt, it was time to find the actual engine!
I was searching on Ebay, the internet, and Craigslist for an engine with a trans. I was looking for the right balance of age, horsepower, and of course cost. Sounded easy at first, but it’s not. Money always gets in the way; I found lots of engines that I wanted but couldn’t afford…pretty JDM STI engines from the early 2000’s for $+/-3,500. I found some 1994-1997 Twin Turbo engines for $750 (budget YES), but add a newer trans (easier to convert) and a single turbo and you are at $1,700 for a +/-16 year old engine. Not really what I was looking for. Not to mention, I kept hearing about how a lot of the JDM engines are not actually “low mile”, all of them advertise as 40,000-60,000 miles, but I saw real evidence of 90,000 mile engines out there (re-sealed head gaskets, etc.). So I kept looking.
I was finally about to pull the trigger on a 1999-2002 EJ208 (newer twin turbo) with a newer trans for $2,000 when I found a mislabeled engine on Craigslist. It was listed as a 2008 2.0 liter WRX engine for $2,000. The picture showed an aluminum intake manifold, so I immediately knew something was off. First there are no 2.0L WRXs in 2008 (all 2.5L) and the 2008 year has a plastic intake. I chalked it up to a scam, but the ad was up for a couple of weeks and then he lowered the price…so I figured, “what the heck” might as well look at it! I go over and sure enough, it’s a 2003 engine with transmission. The guy must have gotten the 8 confused with a 3 and really didn’t know (he’s a body shop guy, he bought the car for the body parts). I double checked the transmission code, found the date stamp on the intake and the underside of the oil cap verifying the right date. So we came to a deal and I took it home!
Here it is being unloaded...
So fast forward through a kitchen remodel, new deck hand railing, and some new tile flooring and a lot of painting….and here we are! During this time, I’ve collected a lot of parts: radiator, aftermarket ECU, wideband O2 sensor, timing belt kit w/water pump, gasket set, 930 axles/CVs, headers, etc…
So finally this weekend, I moved some stuff around in the garage and got the Subaru engine on the engine stand. Covered all the openings I could find on it, and pressure-washed the engine and trans.
Here is the dirty engine/trans on the stand
Now it’s clean!
I did get a little water in the engine, so I started removing the parts I don’t need and the ones I need to modify. I took off the turbo and the exhaust. I also removed the oil pan and filter.
Next, I need to start taking the intake and top side of the engine apart. I need to work on a breather system, remove the tumble generator valves, remove the fuel injection rails so they can be modified for AN fittings, remove the rocker covers so they can be powder coated, change the sparkplugs, replace the timing belt and water pump, replace a broken timing belt cover (behind the cam pulleys…ouch), paint the timing belt covers, turn the intake around (powder-coat that too), blah, blah, blah. I definitely have a few things to work on! And that is just the engine, I haven’t even started to do the transmission ring/pinion conversion!
So here we go! It’s time to get started!
