1958 Ragtop Bug, with turbo EJ22 Subaru power.
crimson ghost
Re: Autocross 58 ragtop, soon with EJ22 Subaru power.
Post by crimson ghost » Wed Jul 13, 2011 5:25 pm
In for updates :D
volkdent
Post by volkdent » Wed Jul 13, 2011 11:58 pm
Just one more option for the coolant line, I cut out my jack mounts so the coolant lines tuck right into the notch between the body and the pan. The little plastic tap was just a thought, and I ended up with a much better and simpler option of cutting small slots at the top part of the pan lip to allow a hose clamp go through, then it wraps around the coolant line and back around again, tucking the line in that gap tightly and simply and out of the way from getting squashed or damaged. I used pieces of a rad hose behind the cooland line to keep it from rubbing on the pan, right under where the hose clamps clamp.
Jason
55superbeetle
Post by 55superbeetle » Thu Jul 14, 2011 12:12 am
That looks really good! I'm still pissed I wasn't at Bugorama to meet you and check out your car in person. Your car looks very very cool, I love the look!
capsoval
Post by capsoval » Thu Jul 14, 2011 12:17 am
Hey Jason, what ever happened with your Go-Pro's from BOR67. Ive been waiting to check out your incars.
My Turbo Build>> http://www.shoptalkforums.com/viewtopic ... 9&t=122882
480whp/300wtq>> http://www.youtube.com/watch?v=6-RvkpiTmr4
Special Thanks to 55superbeetle, Jeff @ 40Thirteen fabrication
volkdent
Post by volkdent » Thu Jul 14, 2011 12:49 am
Sorry, my nube attempt ended up erasing the shots! I think I had them, but I didn't have the software set to start automatically, so all I saw was a single frame, thought I screwed up the settings for recording, and erased it! :/
Humble
Post by Humble » Thu Jul 14, 2011 11:43 am
D: That sucks, guess you'll just have to come out the the next autox and get some in car footage ;) I believe a couple of the buggies come down from your end of the bay
MinamiKotaro
Post by MinamiKotaro » Thu Jul 14, 2011 1:54 pm
Tagging for future reference.
'67 Beetle, 2276
MS-1 v3.57
itawolf
Post by itawolf » Thu Jul 14, 2011 5:41 pm
still looking good roach!! dang your car looks like mone!!! U still have that photo i sent ya??
and since the twisters came thru here...ive been finding parts all over the place!!!
Hint hint!! I need a 60or older gas tank!! hince mine is FLAT!!!
RET Marine 0317 --with VW on the lobe!!
Lots of iron in the fire
itawolf
Post by itawolf » Fri Aug 26, 2011 6:15 pm
$10 gas tank??? i see it written on the tank!! i want/NEED one!!
roachghia70
Post by roachghia70 » Tue Aug 30, 2011 8:42 am
itawolf wrote:$10 gas tank??? i see it written on the tank!! i want/NEED one!!
PM sent
Autocross 58 Bug Build: viewtopic.php?f=19&t=134433
itawolf
Post by itawolf » Tue Aug 30, 2011 5:00 pm
THX Roach
I guess im gonna have to Samba to see more of ur build!! Shame on u!! :lol:
looking good bro
pm sent back
panel
Post by panel » Mon Nov 28, 2011 9:44 am
Just read this post...........Love the clean install :!:
Subaru JDM EJ20 Turbo bus
surfbeetle
Post by surfbeetle » Fri Dec 02, 2011 1:56 am
Can you tell me about the radiator, what is it, where did you get it and cost if you don't mind? I'm undecided on what radiator to use at the moment. I want the tanks on the sides like yours but so far all I have found that are in the approximate measurements is a civic radiator that has top/bottom tanks.
thanks
roachghia70
Post by roachghia70 » Sat Mar 09, 2013 3:47 am
Long overdue updates!!
1. A new look:
2. Autocross in-car video:
http://www.youtube.com/watch?v=dlgOVlUQQEY&feature=plcp
I seized the engine in that video. Watch for the tiny itty bitty flicker of the red oil light at 1:21. Damn. That was the second seizure due to oil starvation, so I got a 3 quart Accusump and am in the process of installing it this weekend.
3. To fix it, I found a 140,000 mile engine at Picknpull for $159.
I got it installed and running, but drove it around the block and it made no oil pressure once it got hot. So I took it back there and got store credit. Look how clean it is, sitting in the junk bin!
Next, I bought a $120 engine off Craigslist, and it is in the car and running now! whoo-hoo!
roachghia70
Post by roachghia70 » Sat Mar 09, 2013 4:29 am
4. Since it runs and he hates it when my cars run, Jeff (55Superbeetle) talked me into turbocharging it. He gave me a free WRX turbo, and offered to TIG all the stainless tubing. Sooooo....
This thing is going to have amazing ground clearance now!! Jeff has done amazing work so far, even taking the time to fill the piping with welding gas on the inside while welding on the outside. All to promote a cleaner and stronger weld. You can see the tape plugging the holes that won't get hot, and aluminum foil on the hole that did get hot. you can also see the clear hose feeding gas inside:
Maybe some of you are used to that kind of stuff, but I was blown away. Like NASA itself was building my doodlebug header. haha
He's planning to have the charge pipe and intake pipe done this weekend. I'll update with more pictures soon!
5. Finally, new wheels:
17x9 rear, 17x7 front. Rota "Fox" replica RSR Fuchs.
