If you have good air flow through your radiator on the move the fan wont come on real often.Mooosman wrote:Buggin_74 wrote:
gen1 EJ engines like this turn the fan on at 96c/205f and back off at 90c/195f so thats a good indication of how accurate a temp gauge is.
Yeah, my gauge reads about 218-220F when the computer turns the fan on, and it turns it off a little over 200F. So, at least it seems to be consistently 15F high.
I actually don't think it's going to need to run the fan that often. I drove it around today in 95F heat, and the fan never turned on once, even sitting in traffic for a few minutes.
My problem for tomorrow is going to be messing with the speed sensor again. My magnet thing isn't working too well, and I'm getting the stalling problem while pulling up to stoplights again. Very annoying. So, looks like I'll be surfing eBay for a proximity sensor and building the "wheel of death" for the CV joint. Do you happen to have a link to the scale drawing of it? I think I've seen the template for the Vanagon guys, but do Vanagons use the same CV bolt pattern as beetles?
Nick
You know how tiny my little radiator is, I put over 1000kms on it before the fan came on of it's own accord, and that was from sitting in bumper to bumper traffic for a good 10 mins.
More dejavu, my magnetic reed sensor didn't last long either.
that proximity sensor has proven itself in all sorts of crappy weather conditions, and 2 other people have also used it.
The Vanagon CV bolt pattern is bigger, I just used the template to get blade shape and spacing then added the beetle PCD for the bolts.
The template was in the Subaruvanagon archives, but I've long since deregistered as the 10+ emails a day was driving me nuts.
I'm pretty sure I have a PDF of it though saved in my subaru folder.
I'll see if i can find it and email it too you.
