Top end rebuild
Moderator: Marc
Dean...
Top end rebuild
Post by Dean... » Fri Aug 18, 2017 7:20 am
Hi again everyone
I think I might freshen up the top end of the engine in my bug. No doubt having water in the cylinders has done damage, so I'd like to pull the heads and check that all is well, and replace the cylinders/pistons and rings. My engine is supposed to be a 1916. Does anyone know if the kit in the pic of what I need?
DeanImage
Sent from my Pixel XL using Tapatalk
dragvw2180
Re: Top end rebuild
Post by dragvw2180 » Fri Aug 18, 2017 11:12 am
They should work perfectly unless you are really going to run it real hard , then I might spend the money for better ones.
Dean...
Re: Top end rebuild
Post by Dean... » Fri Aug 18, 2017 5:17 pm
Great, thank you!!
