1302 fuel filler flap size?
Moderator: Marc
Tony Z
Post by Tony Z » Sat Apr 15, 2017 12:06 pm
I was doing a little work on my 1302 when I noticed that the filler flap seems a bit small for the hole it fits into. I can see the fuel filler cap through the gap. Also, I had to do some work on the pull wire/pin to make it 2mm shorter so I could open the flap.
If you are wondering, I havent driven this car yet and am rebuilding it VERY slowly.
I then looked at a 1303 and see that this flap is also small for the hole it fits into, but this flap is clearly from a different vehicle.
Anyway, my question
is the filler flap from a 1302/3 a different size to one from a "normal" sedan?
dawie
Re: 1302 fuel filler flap size?
Post by dawie » Mon Apr 17, 2017 10:31 am
Seems that filler flap is indeed different.
From a British forum: "1302 fuel filler flap is unique to the model and has a different shape"
Tony Z
Post by Tony Z » Mon Apr 17, 2017 12:04 pm
Thanks Dawie.
Guess I'll have to make a plan then...
