rim question?
VW_Man_87
rim question?
Post by VW_Man_87 »
i am wondering whats the size of just my rims, i know they are 15x?
here is a picture of them....:
i think it is a 15x7 rim because i would like to put these tires on my car after i get done with body and suspension modifications:
http://www.intercotire.com/tires.php?id=8&g=1
thanks
Jeremy
im in need of a new front clip for my 74 ghia, i dont care what year its from but i need one in order to fix my front end, can anyone help out?
harryset
Re: rim question?
Post by harryset »
Check and see if it's stamped on the backside of the wheel somewhere.
'72 Standard
"I am the proud owner of a "Hoover Bit".
185 60's, EMPI disc kit, EMPI 2 1/2" dropped spindles on the front.
185 65's and stock binders on the back.
SecondSkin - Damplifier Pro and Luxury Liner Pro for sound control.
VW_Man_87
Re: rim question?
Post by VW_Man_87 »
ok will do... if not ill post back
VW_Man_87
Re: rim question?
Post by VW_Man_87 »
no stamp on them but my current tire size is 165 r15 86t
Marc
Re: rim question?
Post by Marc »
I seriously doubt that they're 7", more likely ~5".
Stock rims for a late `Ghia were 4½", made with slightly more backspace than a Beetle rim to increase the rear fender clearance. Use of anything else (or a Type III rim) and/or a wider tire can present problems there
Are you seriously contemplating running 34x9.50-15LT Super Swampers on a Karmann-Ghia? :roll:
They won't even fit on a Beetle without changing the torsion bars and whacking the body, don't know if you could cut enough out of a 'Ghia to get them in...what do you plan to do about the gearing?
VW_Man_87
Re: rim question?
Post by VW_Man_87 »
when im done with fenders and suspension lift (as im working on doing a baja style) these tires im wondering if they would mount to my rims so i dont have to buy new rims
Marc
Re: rim question?
Post by Marc »
Well, they're intended for a 7" rim but you can shoehorn nearly anything on. I wouldn't recommend it though, putting an 8" tire on a 5" rim will make for squirmy tracking on the road and you'd need to run low pressure to keep the contact patch flat.
VW_Man_87
Re: rim question?
Post by VW_Man_87 »
hmmmm, ok.... maybe i will just buy new rims when i do get to that point
Marc
Re: rim question?
Post by Marc »
Or you could go a little more conservative on the tires...my son found some 7.00-R15s for the front of his baja, they fit fairly well on a narrow rim and are a little smaller in diameter so they should clear the rear torsion bar caps. Lighter weight, too.
The gearing change compared to stock would only be half of the ~25% you'd get from those Super Swamper monsters.
http://img.photobucket.com/albums/v212/ ... 290160.jpg
VW_Man_87
Re: rim question?
Post by VW_Man_87 »
hmmm ok, do you have a link to those tires?
i plan on having all 4 the same and 1 for the spare
Marc
Re: rim question?
Post by Marc »
Don't have one handy, I'll have to ask him where he got them.
VW_Man_87
Re: rim question?
Post by VW_Man_87 »
ok thanks, im old school i like to have a full size spare with me at all times
VW_Man_87
Re: rim question?
Post by VW_Man_87 »
hey Marc have you figured out any sources on those tires you son has on his baja?
Chris V
Re: rim question?
Post by Chris V »
I don't remember where I got them, but they're just Yokohamas...I think they're stock equipment on some Isuzu work trucks.
VW_Man_87
Re: rim question?
Post by VW_Man_87 »
ok what size are they?
