My 72 Bug
- Lew
Line X Material!
I'm glad I had it done David. It was worth the money having the bottom sprayed....I am thinking between the Line X on the bottom and installing Fatmat on the inside, it should help on quitening down a good bit of road noise also.
I should be able to get my rebuilt front beam, the rear swing arms and freshly painted transaxle in tommorrow. I might have a rolling chassis soon. I got all the parts, just need a little more time.....No picture till it's rolling.
It's still in the Restoration Booth!
You can take a peek!
VW Help
VW Technial
Track Gas Mileage
The Class I Teach
VW Help
VW Technial
Track Gas Mileage
The Class I Teach
- Lew
I need this Rubber Bushing. I cannot find it on California Imports Site. It protects my hard Brake Line where it passes through the rear cross member of the chassis.
VW Help
VW Technial
Track Gas Mileage
The Class I Teach
VW Help
VW Technial
Track Gas Mileage
The Class I Teach
- sideshow
This is a split type, the factory ones are like an umbrella but I don't think anyone is reproducing them (I suspect they were installed before the fittings & flare).
http://www2.cip1.com/ProductDetails.asp ... 16-211-751
- Lew
Yep, your right the original ones are like you said, and that's what I have but it's shot. I got somethings in my cart from CPI1 but they are updating their site as I post this message....They are going back to their regular pricing as of last night at 12. Crapola! At ten, their prices were still 30% off on their site. OH well, life is tuff and then you die...... I appreciate your help Sideshow!
VW Help
VW Technial
Track Gas Mileage
The Class I Teach
VW Help
VW Technial
Track Gas Mileage
The Class I Teach
- Lew
Before and After!
Remember before it was Line X'ed.
Nice and Thick! Gotta help on supressing Road Noise......
VW Help
VW Technial
Track Gas Mileage
The Class I Teach
VW Help
VW Technial
Track Gas Mileage
The Class I Teach
- Lew
My Trailing Arms ready for installation.
VW Help
VW Technial
Track Gas Mileage
The Class I Teach
VW Help
VW Technial
Track Gas Mileage
The Class I Teach
- Lew
Getting some things put back together.
The mounts are in place and the Transaxle cleaned.......
VW Help
VW Technial
Track Gas Mileage
The Class I Teach
VW Help
VW Technial
Track Gas Mileage
The Class I Teach
- Lew
My Beam almost done. After I installed the Beam and Rotors, I pondered over Backing Plates. I could have run without them, but I felt it best to have them.....So, I ordered Backing Plates from CIP1 which I thought would fit without any problems. Well, I was wrong, they were for the Ghia, and since I had new dropped spindles, they had no mounting holes for the BP's. I tried Installing them using the bolts that held the calipers in place in reverse order,(the green arrows) but found the bolt heads rubbed against the rotors, plus they were not enough support to keep the Backing Plate from flexing away from the spindles.....After some thought, I figured the only way to mount them was to drill out the marked holes at the yellow arrows. The red circle is my first tap using a short 5/16" bolt. My second tap was 180 degrees from my first tap.....That then gave me the support holding the BP's tight against the dropped spindles, therefore there was no need for the third bolt. A dry run with the Rotors in place gave good spacing for the BP's.
Good clearance and spacing now!
VW Help
VW Technial
Track Gas Mileage
The Class I Teach
VW Help
VW Technial
Track Gas Mileage
The Class I Teach
- Lew
VW Help
VW Technial
Track Gas Mileage
The Class I Teach
VW Help
VW Technial
Track Gas Mileage
The Class I Teach
- Lew
Dry Fit on Joints and Axles!
After I cleaned and inspected the CV Joints, they were re-installed in their original postion,
then the entire axle was turned over so CV Joints are now turning in the opposite direction
from their original rotation. The Axles are still turning in their original rotation since I swapped
ends on the Axles when installing the CV Joints. The Ball Bearings will now ride on a new
space on the splined Ball Cage. Now after the dry fit, all they need is joint grease.
VW Help
VW Technial
Track Gas Mileage
The Class I Teach
VW Help
VW Technial
Track Gas Mileage
The Class I Teach
- david58
- Lew
I have definetly thought about new wheels. I am not sure what I want.....I am somewhat leaning toward the Empi spokes, or the BRM flat fours.....There are so many wheels out there to choose from....I have looked around on Samba and found some nice looking used wheels, but I think I would prefer new ones......I do want to get the right set up with wheels and tires......Sizes are important as to the stance I want.....Just not sure right now what would work well on the car.....Any help or ideas would be helpful......
VW Help
VW Technial
Track Gas Mileage
The Class I Teach
VW Help
VW Technial
Track Gas Mileage
The Class I Teach
- david58
What stance are you looking for? There are plenty of pics on here look thru them it may help you decide on the wheels you want.Lew wrote:I have definetly thought about new wheels. I am not sure what I want.....I am somewhat leaning toward the Empi spokes, or the BRM flat fours.....There are so many wheels out there to choose from....I have looked around on Samba and found some nice looking used wheels, but I think I would prefer new ones......I do want to get the right set up with wheels and tires......Sizes are important as to the stance I want.....Just not sure right now what would work well on the car.....Any help or ideas would be helpful......
