How tight is the sump extension tube on a 1.5 qt Berg Sump supposed to be?
Found the following on my brand new Brazilian case bought from RIMCO:
Sump Tube ID = 0.625"
Case Tube OD = 0.710"
Directions say to tap the extension on - there is no way mine will fit without flaring the sump tube.
Did I get the wrong size extension? Next size up is listed as 3/4" - if this is ID then I think it will be to big.
Suggestions?
Berg Sump extension tube
- Tom Notch
You should be using the larger tube. That is what the late cases use. I think it is actually smaller than what Berg calls it. Mine is buried in 7 qts. of oil or I would measure it for you.
Tom Notch
Tom's Old VW Home
Tom Notch
Tom's Old VW Home
Called Berg - looks like I have the wrong tube. They are sending another.
Thanks.
Thanks.
