Estimated horsepower
hotair
Re: Estimated horsepower
Post by hotair »
Ok tell me....😳
2332
FK43 cam
Eagle 5.4 “ rods
Wiseco pistons
Pauter 1.4 roller rockers
Street eliminator heads 37x44 valves
Twin Weber 44’s
What kind of power will this make???
Thanks....
ps2375
Post by ps2375 »
Not that I know anything about that cam, but seems you are missing some additional specs. Like CR, exhaust choice, vent size and any porting anywhere. Definitely more than 100whp, but that could also depend upon who assembles it. I would think an easy 120+ at the wheels.
hotair
Post by hotair »
Sorry.....heads are ported and the intakes matched to the ports. The exhaust is 1-5/8 tri-mill. I’m not sure about the vents, the carbs are still in the box from CB. The cr is about 9.5-1 I am also using a pauter dry sump system.
ps2375
Post by ps2375 »
I stand by my prediction then, and add that it'll be really fun. My 2087 made 114whp on less compression and with your added cc's and compression..more power should be no problem.
Teo1303
Post by Teo1303 »
Hell guys ... will you tell me some information for me also???
My engine is going to be with these specs
Full flow engine with 94x78 (2165cc) , FK8 Engle camshaft , 1.4 rockers , 40x35.5 heads , 2dual 40 Dellorto's DRLA
I don't know how much the compression is yet and how much can this engine rev with the stock rods from a 1584cc engine ?? 5,800 RPM is enough or I can go further to 6,500??? What kind of power will this engine make ???
