The ballast resistance required is dependent upon the particular ignition system or ignition module that you are using.
Jacobs ignition computers DO NOT require a Ballast resistance.
Points and most points replacement ignition modules require a minimum total ballast resistance of at least 3.0 ohms.
Example: A Jacobs ignition coil with a Primary resistance of 0.4 ohms requires a Ballast resistance of about 2.6 ohms to equal the 3.0 ohms minimum total ballast resistance required for points and most points replacement ignition modules.
A smaller total ballast resistance will allow too much primary current to flow which could overheat the ignition coil and ignition module and damage them. You can use a larger ballast resistance, but I'd keep the maximum total ballast resistance to no more than 4.0 ohms, as you lose spark energy as the ballast resistance increases.
Also note that I do NOT recommend ignition modules mounted inside a hot distributor. I believe that it is more reliable to use points, or a reluctor and magnetic distributor pickup to trigger an external electronic ignition system.
By only using an electronic points eliminator ignition module to trigger an external electronic ignition system, the module will run cooler and more reliably.
Also note that many electronic ignition modules are susceptible to voltage surges and voltage spikes and that some sort of filter and voltage limiter should be used.
Allison was purchased by Crane
Any older Allison Optically triggered ignition system requires a minimum total ballast resistance of 3.0 ohms.
http://www.cranecams.com/
Instructions for XR-700
http://www.cranecams.com/pdf/90000700.pdf
XR-700 must use 3.0 ohms or greater
Instructions for XR-3000
XR 3000 does not require a ballast resistor.
While no warnings are given by Crane/Allison, if the ignition key is left on while the engine is NOT running the Crane/Allison ignition system, and, or ignition coil may fail.
http://www.empius.com/
http://www.empius.com/2009_catalog/empi2009_pg111.html
The Empi Accu-Fire appears to lbe a knock off of the Compu-Fire ignition modules and may in fact be Compu-Fire with an EMPI label.
Accu-Fire makes NO statement whatsoever about the required ballast resistance. As such assume that you need a minimum of 3.0 ohms total ballast resistance.
While no warnings are given by Accu-Fire, if the ignition key is left on while the engine is NOT running the Accu-Fire ignition module, and, or ignition coil may fail.
http://www.compufire.com/
Compu-Fire VW-1 Ignition Module instructions
http://www.compufire.com/pdf-instructions/21100.pdf
Compu-Fire VW-2 Ignition Module Instructions
Compu-Fire makes NO statement whatsoever about the required ballast resistance. As such assume that you need a minimum of 3.0 ohms total ballast resistance.
While no warnings are given by Compu-Fire, if the ignition key is left on while the engine is NOT running the Compu-Fire ignition module, and, or ignition coil may fail.
http://www.compu-tronix.com/index.htm
http://www.compu-tronix.com/VW009.htm
Instructions for VW009:
http://www.compu-tronix.com/VW009InstructionSheet.pdf
Requires a minimum of 2.4 ohms total ballast resistance
"The COMPU-TRONIX™ automatic shut down feature automatically turns the ignition system off- one second after the engine stops turning."
http://www.hot-spark.com/
Instructions:
http://www.Hot-Spark.com/Installing-Hot-Spark.htm
The Hot Spark module requires a minimum total ballast resistance of 1.5 ohms.
While no warnings are given by Hot Spark, if the ignition key is left on while the engine is NOT running the Hot Spark ignition module, and, or ignition coil may fail.
http://www.malloryperformance.com/
http://www.malloryperformance.com/pdf/Distributors.pdf
Mallory Unilite ignition modules require a minimum total ballast resistance of 1.4 ohms.
While no warnings are given by Mallory, if the ignition key is left on while the engine is NOT running the Unilite ignition module, and, or ignition coil may fail.
Mallory MBI ignition modules (Magnetic Breakerless Ignition ) require a minimum total ballast resistance of 1.4 ohms.
While no warnings are given by Mallory, if the ignition key is left on while the engine is NOT running the MBI ignition module, and, or ignition coil may fail.
Mallory 540 & 550 Magnetic Breakerless Conversion Kit instructions:
http://www.malloryperformance.com/pdf/540.pdf
Mallory 540 & 550 Magnetic Breakerless Conversion Kits require a minimum total ballast resistance of 3.0 ohms.
While no warnings are given by Mallory, if the ignition key is left on while the engine is NOT running the magnetic pickup amplifier , and, or ignition coil may fail.
http://www.pertronix.com/prod/default.aspx
Pertronix Ignitor I
http://www.pertronix.com/prod/ig/ignitor/default.aspx
Instructions for Ignitor I
http://www.pertronix.com/support/manual ... 12vneg.pdf
Pertronix makes NO statement whatsoever about the required ballast resistance. As such assume that you need a minimum of 3.0 ohms total ballast resistance.
While no warnings are given by Pertronix, if the ignition key is left on while the engine is NOT running the Pertronix Ignitor I ignition module, and, or ignition coil can fail.
Pertronix Ignitor II
http://www.pertronix.com/prod/ig/ignitor2/default.aspx
Pertronix makes NO statement whatsoever about the required ballast resistance. However they do state that it may be used with a 0.6 ohm ignition coil. Ask Pertronix if you can use a coil with less than 0.6 ohms primaty resistance without a ballast resistance.
"Senses incorrectly wired Ignitor II or a "key left on" condition and shuts down the system protecting the coil and other components from damage."
Scott Novak
