converting baywindow to wide 5 question.......HELP!!
Moderator: doc
Jadewombat
Contact:
Re: converting baywindow to wide 5 question...
Post by Jadewombat » Fri Sep 04, 2009 12:55 pm
MkV GTI/GLI Detroit rims
Post by Piledriver » Fri Sep 04, 2009 1:22 pm
Jadewombat wrote:MkV GTI/GLI Detroit rims
Those would look awesome on a Bay.
(Or most anything else)
mattography
Post by mattography » Fri Sep 04, 2009 5:43 pm
Some of this may help in what you’re looking to do. The Vanagon is also 5x112 and these may help in finding the correct Wheel Nuts, Wheel Studs and Wheel thickness
http://www.thesamba.com/vw/forum/viewtopic.php?t=203519
http://wiki.club8090.co.uk/index.php/Wh ... ive_wheels
TexasAirCooler
Contact:
Post by TexasAirCooler » Mon Sep 07, 2009 7:39 am
Yes, but what is the back spacing on those?
Terry
'65 13 window deluxe bus • restore project
Post by Piledriver » Mon Sep 07, 2009 9:05 am
Probably in the ballpark...
mattography
Post by mattography » Wed Sep 09, 2009 2:50 pm
Monza/Detroit/Hufweisen BBS 18" wheel - 18x7.5 et 51 - 29lbs each
slammed73hightop
Post by slammed73hightop » Sat Sep 12, 2009 3:30 am
""CLICK ON PIC FOR LARGER VIEW""
so this is my bus (after a full air suspension and 5inch narrowed beam is installed) and those are the wheels i found for her, they're 18's (5x112), they do come in 17's but not the 5x112 bolt pattern.they have a 40 offset. so what am i going to have to do to make them fit properly?the wheels are 7.5 wide, will that be a problem around back, with rubbing at all?
mattography
Post by mattography » Sat Sep 12, 2009 2:58 pm
Do you know the center bore?
I think that is going to be your largest problem.
Great pchop,
Chris V
Post by Chris V » Sat Sep 12, 2009 7:12 pm
slammed73hightop wrote:...the wheels are 7.5 wide, will that be a problem around back, with rubbing at all?
I've got 17x7.5's on my bus and it's been tight even at stock height...I don't know what problem arise when lowered...
With 235/45's no problem, with 235/55's I had to run a ~8mm spacer to get the tire off the springplate in my case...and there's approx. zero room between the fender :wink:
http://img.photobucket.com/albums/v212/ ... 010040.jpg
Jadewombat
Contact:
Post by Jadewombat » Mon Sep 14, 2009 10:05 pm
Well, I found out something new yesterday about Mercedes rims. I'm running 16 inch CLK rims on my bus here. I have no issues of the hub not being big enough for the dustcap/axle nut, etc. which was asked about.
I'm also leasing an '09 C300 Sport that comes with 17 inch rims.
I was curious to see if the 16s would fit on the C300, yes and no. The bolt pattern is the same, the rims don't bind on the calipers or anything, but the hole size is different. This is the first year from what I can tell that Mercedes has done this. I spent quite a bit of time swapping over to smaller studs on my bus I put up earlier in this post. The 'new' models take a bigger lug, 14 x 1.5mm. Does anyone know, is this what bay buses and vanagons use??
Moral of the story, just because the bolt pattern is the same, 5x112, doesn't mean it'll simply bolt on.
Chris V
Post by Chris V » Tue Sep 15, 2009 2:44 am
Yes, 5x112 Bays and Vanagons are M14x1.5...
Audi uses 5x112 M14 studs...just with smaller hub-centric bits, so they must be opened up to fit in some cases.
It's pretty normal for Mercedes rims to be either M12 or M14 depending on the size of the vehicle...smaller vehicles, smaller studs...The advantage to MB is I've never heard of any hub-centric issues.
WestyPop
Post by WestyPop » Thu Sep 24, 2009 11:58 am
Anyone see any strength issues for a loaded baywindow bus or Vanagon high top camper, in switching from 13mm studs/lugs to the smaller 12mm size? (My German Ford Scorpio also uses 5 x 112 wheels with 12mm studs, but it doesn't get loaded quite as heavily as the Westy!)
Jadewombat
Contact:
Post by Jadewombat » Sat Sep 26, 2009 10:09 am
WestyPop wrote:Anyone see any strength issues for a loaded baywindow bus or Vanagon high top camper, in switching from 13mm studs/lugs to the smaller 12mm size? (My German Ford Scorpio also uses 5 x 112 wheels with 12mm studs, but it doesn't get loaded quite as heavily as the Westy!)
My '66 bus empty weighs 2800lb. A small Mercedes is about 3400lb., so no it shouldn't be an issue. Studs rarely break, remember the stud isn't carrying the load from the side, it's holding the load by 'nailing' the wheel to the hub.
volksbugly
Detroit gti wheels
Post by volksbugly » Fri May 19, 2017 1:34 am
I have a set of the detroits for sale:
originally I was going to put these on my bug, but I am doing porsche suspension now so this is going to be cost ineffective for me. Initially I was asking 1600, then dropped the price several times... I Just dropped it to 750$ Grab them now they wont stay long!
https://www.thesamba.com/vw/classifieds ... id=2049140
