convertible top for a 73 Ghia
Posted: Mon May 02, 2016 6:09 pm
by Speedy
I'm attempting to install the frame & I'm having an issue with the main bow protruding past the door pillar when the frame is fully closed. From what I can tell, after reading all the instructions I've found, the main bow should be flushed on the surface & 6mm above the door post. My frame moves very freely, does not appear to be bent anywhere & this is on both sides. I've attached a photo, although from the photo appears to be lined up, but when fully closed it protrudes 1/4" past the door pillar. When I purchased the car, the top was already off. Any suggestions???
Speedy (Irene)
