HELP! Wheel locked up.
- Bonemaro
I'm trying to get the Ghia on the trailer, but the rear passenger wheel won't move. Brakes? Transaxel?
Any tips?
Any tips?
Jim
My 1973 Karmann Ghia---> http://www.73ghia.com
Re: HELP! Wheel locked up.
Open the bleed screw on the locked wheel to see if there is a problem there. It may relieve the pressure caused by a bad soft hose or a locked up wheel cylinder.
Release parking brake.
Had to be said.
Anyway. Park brake off, remove wheel, smack drum with hammer repeatedly
Usually you can hear the shoes retract when they unstick.
Had to be said.
I have used a drift to get in with wheel still on with varying success
- Bonemaro
Jim
Also. Remove the shoe inspection covers on the backing plate and you can sict a screwdriver in there and directly work on the pad itself
- Bonemaro
Hammer did the trick. Thanks y'all.
Jim
Wonderful.
The technical term is "impact adjustment performed with BFH"
ROFLMAO!!!helowrench wrote:Wonderful.
71 Ghia Coupe........For Sale
63 IH Scout 80 (beater)
Or... "bang the gong slowly".helowrench wrote:Wonderful.
Both rear wheels were locked up on the '71 Ghia I just picked up - I backed off the shoe adjusters & used the 'applied physics' method as well.
The BFH... then, on the way home during the 10 mile flat tow, the right front wheel decided to lock up - yoinked the caliper bolts out, pulled caliper &
tucked it into pan recess, then zip-tied it safely out of the way & continued tow home - no problems.
bryan
bryan
