kindly I have the EMPI 38 EGAS Carburetor Kit part number 47-0645 for type 4 engine 2 liter engine
also i have installed Fuel Pressure regulator part number 9102 and put it on 2 as recommended since i am using a mechanical fuel pump
the problem is that i have a lot of hesitation from 1000 to 2000 rpm
please advice me if any setup must do in order to fix this problem
thank you
