Ring and Pinion on EBayers for Auto....
Hey, seem this on ebayers...# 280438793610 Bill,jr.
- raygreenwood
Re: Ring and Pinion on EBayers for Auto....
Hmmmm very cool! Ray
So how Auto and Manual ring and pinions? Bill,jr.
Will these work in the later 010 gear boxes or are they 003 specific?
- raygreenwood
What does the 010 go into? They will be specific to the type 3 and 4 layout. It shoudl fit either type 3 or 4 automatic. Ray
If I have my tranny numbers and years right the 010 came in the later bays and the 090 came in the Vanagons. I was actually wondering if this gear set could be used in a Vanagon with a TDI or other higher torque engine.
raygreenwood wrote:What does the 010 go into? They will be specific to the type 3 and 4 layout. It shoudl fit either type 3 or 4 automatic. Ray
- raygreenwood
Its possible.....but the gear ratio having more teeth on the bus...generally makes it a larger diamter ring. What ends up happening usually is that the differential housing then gets to be too fat to fit the ring gear onto. Ray
