Compufire vs Petronix
I know that a real electronic iginition would be best, but I want simple and low profile. Is there an advantage of one system over theother, or are both essentially the same? Plan to do this in a '74 2 liter 914 with stock everything else.
I've heard the same, and tried several units of both. I keep buying Pertronix for it's better quality build and less crack prone design of the magnetic collar. Nice silicone wires, and ruber grommet for the dizzy body to keepo water out. Overall better quality parts and more thought put into it.
I had a Compufire disc grenade on me at 3am when launching from red ligts just outside of the city. Not fun. The Pertronix magnetic collar wil NEVER see such centrifugal forces, due to design. I've taken the pertronix past 9000rpm without a glitch, ever.
I'd go with Pertronix, from www.aircooled.net -they promised to replace units that are broken out of the box, without a hassle. Never had a bad one, I've used them for years and have bought maybe half a dozen or more. They don't fail under use, if you got a bad one it was bad from the manufacturer and you get no spark.
Oh and just in case you were wondering, there's also Accu-Fire, sold by Bugpack. It's an exact copy, or perhaps even the same item, as Compufire.
Jan
Jan
- MinamiKotaro
Best
We have Sold and Used both and also used some of the cheaper brands and find no difference in any of them. At one time we thought there might be an advantage to the larger diameter rotor but this did not prove out. We thought the name brands might be better Quality but this did not prove out. We have found that 90% of all problems come from not reading instructions. (hooking up a wire wrong) or leaving a key on. In some cases the screw that held the condenser was slightly to long once the condenser was removed. See -> Electronic Ing. How to Install <> http://www.1800vw.bizhosting.com/electronicing.htm This has been one of the best thing for the VW outside of the Stainless Steel Exhaust valves.
- MinamiKotaro
Re: Best
This is important. My Ignitor II instructions didn't say to leave the condenser can screw out, so I put it back to plug the hole. The thing didn't work worth a crap.vicsvw wrote:In some cases the screw that held the condenser was slightly to long once the condenser was removed.
So, we got a Compufire and its instructions did contain a note to leave out the condenser can screw once you took it off. We took the little screw out of the distributor with the Pertronix in it and, boom, it suddenly worked great.
Perhaps the Pertronix people didn't think anyone would put the screw back in.
'67 Beetle, 2276
MS-1 v3.57
MS-1 v3.57
Is there a Pertronix Ignitor II made for the 205 distributor?
All i can find is 009 and 050, would this one work?
Re: Compufire vs Petronix
Nocoolj30 wrote:Is there a Pertronix Ignitor II made for the 205 distributor?
Nocoolj30 wrote:IAll i can find is 009 and 050, would this one work?
I may be a little late but pertronix customer service is awesome. I hooked mine up backwards(u know what i mean) they sent me a new one, her about a month ago 2 years later i pulled my plastic collar out and it came apart they sent a new one with no receipt. I dealt with pertronix direct but i had bought the parts elsewere. So if you pull your collar out grab it under itself as much as you can it will pull apart,and you cant get the polarity back I got 3 out of 4 enough to get it out of the driveway.
