2110 horsepower how much?
Moderators: david58, Iguana
vertman
Postby vertman » Thu Jun 12, 2003 1:17 pm
Does anyone know about how much horsepower a 2110 makes. Here are some of the comp. I have not got this motor in yet is being put in as we speak and I'm not sure what to expect. :?
82mm Scat Pro Crank
044 Heads
44 Webers
Merdged Header
Any help would be great.
sparkmaster1
Postby sparkmaster1 » Thu Jun 12, 2003 2:41 pm
what cam, cr, and valve size? Tim
Owner Tim's ACVW Engine/Trans Service
JC-ATL
Postby JC-ATL » Thu Jun 12, 2003 3:39 pm
Man, there are so many variables that influence horsepower and torque that any numbers you get are going to be people pulling them out of their arse.
Unless you build yours identical to one that's been on a dyno, you won't get consistent horsepower with what anyone here tells you.
Travis S
Postby Travis S » Thu Jun 12, 2003 5:15 pm
Get your self a copy of desktop dyno, you can screw around in there, but I don't know how accurate it is. I think I read somewhere it over estimates by like 5-10 hp.
TRACKMAGIC
Postby TRACKMAGIC » Thu Jun 12, 2003 8:14 pm
Desktop Dyno is fun to mess with, but it gives you hp figures assuming you are in an optimal environment. It tends to over rate hp and torque figures by roughly 15-20%
Spike_Spiegel
Postby Spike_Spiegel » Sat Jun 14, 2003 2:51 am
wjere do i get desktop dyno?
TRACKMAGIC
Postby TRACKMAGIC » Sat Jun 14, 2003 12:17 pm
Kazaa.
slow64vw
Postby slow64vw » Mon Jun 16, 2003 10:44 pm
i had a 2110 with vz 35 cam street elmi heads 48 idas 13/4 merged exhaust 9:1 compressin on the street in a 64 vw and it dynoed 184.6@5920rpm
Denny
Postby Denny » Tue Jun 17, 2003 8:24 pm
With a mild cam (engle 120) and a compression ratio at about 8:1. that combination will probably make 140 HP maybe a bit higher. Don't be too concerned about HP ratings or guesstimates though. The big factor is how much low end grunt (torque) it will produce. That's what will put a smile on your face.
Return to “VW's For Newbies”
Who is online
Users browsing this forum: No registered users and 1 guest
