Fuel sender on a standard aircooled Beetle?
Moderator: david58
crankio
Post by crankio » Mon Jun 20, 2016 6:28 pm
Hi, I've just joined the VW family!
What is the correct and best way to install a fuel sender on a standard aircooled Beetle?
Cranky
Re: Fuel sender on a standard aircooled Beetle?
Post by Marc » Mon Jun 20, 2016 6:35 pm
What year tank are you working with? `62-`67 had a mechanical (cable-driven) gauge and later years had an electric one in the speedo.
aussiebug
Post by aussiebug » Mon Jun 27, 2016 8:10 am
There are also two different fuel senders. Up to about 72 they had a single wire connector for power and relied on one of the mounting bolts making metal/metal contact with the tank and then getting and earth through the tank clamps. The later versions have a second connector on the sender for a dedicated earth/chassis connection. The early version can have an earthing wire added under one of the bolts to make a dedicated earth if you have an earthing problem.
The sender'as bolt pattern is asymmetric (one bolt is offset) so the sender will only attach in one direction, allowing the float to move freely inside the tank.
Regards
Rob
Rob and Dave's aircooled VW pages
Repairs and Maintenance for the home mechanic
www.vw-resource.com
