What is a really good synthetic wheel bearing grease to use?
Moderator: david58
Jim Ed
Post by Jim Ed » Sun Jun 19, 2016 9:28 am
TIA!
ONEBADBUG
Re: What is a really good synthetic wheel bearing grease to use?
Post by ONEBADBUG » Sun Jun 19, 2016 1:23 pm
Mobil 1
Post by Piledriver » Sun Jun 19, 2016 5:39 pm
Lucas X-tra Heavy Duty grease even works for CV joints.
I use it on everything that gets greased.
Available ~everywhere.
http://lucasoil.com/products/grease/luc ... uty-grease
Not a fan of some other Lucas products (oil additive just makes foam) , but I like that grease.
Jim Ed
Post by Jim Ed » Sun Jun 19, 2016 10:09 pm
I chose Valvoline SynPower Full Synthetic Multi-Purpose Grease (16 oz.) Part No. VV986 because I saw it on Bob Is the Oil Guy: http://www.bobistheoilguy.com/forums/ub ... 9&page=all
NLGI No. 2 thickness
NLGI GC-LB for both chassis and bearing lubrication
Lithium complex EP (extreme-pressure) MP (multipurpose) grease for most optimal properties
High-temperature grease
Fully synthetic Group III base oil for extreme working temperature range from -40 to 400 F
Contains molybdenum disulphide, which is crucial to prevent scoring of metal surfaces
Contains ZDDP, which is crucial to protect against oxidation of the base oil and metal surfaces
Can be used in all automotive applications for all makes, including disc-wheel bearings and CV joints and high-temperature applications
