A Simple Approach to Re-wiring Your Volkswagen
- david58
To begin wiring your Volkswagen you will need to break the wiring circuits down into separate circuits. I posted the blank diagram above so you can print it out and use it for a work sheet. The diagrams below should be helpful in wiring your VW, but not all year models have the same wiring. Some have alternators and some have generators relays and switches are different. So if you have a scanner then you can post your work sheet and then members here can help you.
Back Up Light Wiring
Horn Wiring
Fuel Stabilizer Wiring
Brake Light Wiring
Wiper Wiring
Oil Light Wiring
Head Lamp and Tail Lamp Wiring
Ignition Coil Wiring
Generator Wiring
Turn Signal Wiring
Starter Wiring
Fuel Gauge Wiring
