Brake Part Numbers
Moderators: david58, Iguana
Brake Part Numbers
Postby david58 » Fri Oct 30, 2009 3:28 am
Brake Parts
Wheel Cylinders
T-1 Wheel Cyl
Rear 57-7/64 # 113611055C
Rear 64-7/67 # 131611055
Rear 67-on # 113611053B .....This is also used on the front of Buggys
Rear T-3 65-73# 311611067C
Front 52-58 # 113611055
Front 57-7/64 # 113611057B
Front 7/64- on except SB # 131611057 .....Also used on Buggy Rear with IRS Backing Plates for better brakes.
Marc wrote:Pre`58 brakes are all different, nobody cares about them unless restoring a split or oval.
113 611 055 and 113 611 055C fit `58 through `64
113 611 053B fits `68↑ (not `67)
113 611 055 and 131 611 057 can be interchanged if needed (only difference is the width of the slot)
You don't need IRS backing plates to use 131 611 057 on the rear, `68 swingaxle will also work.
Dunno why you have Type III parts listed under Type I, but 311 611 067C is the 22mm (7/8") and 361 611 067A is the 23.8mm (15/16") used on early Squarebacks and also on SuperBeetle fronts; 067As are therefore easier to find. They are not interchangeable except in pairs.
Thanks Marc. :wink:
T-2 Wheel Cyl.
Rear 56-7/71 # 211611047C
Rear 72-on # 211611047D
Front 55-7/63 Ft/Left # 211611069
Front 55-7/63 Ft/Right # 211611070
Front 63-7/70 Ft/Left # 211611069C
Front 63-7/70 Ft/Right # 211611070C $12.95
Brake Shoes & Pads
T-1 Brake Shoes
Brk Shoes Ft. 10/57-7/64 # 113 609 237D
Brk Shoes Ft. 8/64-on . # 131 609 237C
Brk Shoes Ft. 8/70-on . # 113 609 237H
Brk Shoes Rear 10/57-7/64 . # 113 609 537B
Brk Shoes Rear 8/64-7/67 . # 131 609 537C
Brk Shoes Rear 8/67-79 . # 113 609 537C
Marc wrote:
113 609 237H is Super Beetle only
113 609 237D are similar to 131 609 237C, the only difference being that the latter have angled ends at the adjuster. If you use the `65↑ adjuster, 131 609 237C fit `58-`64 as well.
Same goes for 113 609 537B and 131 609 537C. I consider this an upgrade, linings wear less unevenly with the angled adjuster/shoe arrangement.
It's common these days to find new shoes made on frames which allow them to be used on either the front or rear (they have both the slot for the e-brake bar and both return spring hole arrangements). You've always been able to use a "rear" shoe on the (same-width) front by simply drilling one return spring hole in it.
The brake industry standard P/N for `68↑ rear shoes is 10153
`65↑ front is 10142
`65-`67 rear is 10143
`58-`64 front is 10078
`58-`64 rear is 10079
Super front is 10199
Type III rear is 10140
`55-`63 Bus rear is 10077
`64-`70 Bus front is 10114
`72 Bus (rear) is 10215
`73↑ Bus (rear) is 10231
I don't have the numbers for the 63½-`67 Bus rear or the early Bus front.
Thanks again Marc for the corrections.
T-2 Brake Shoes
T-2 Brk Shoes Ft. 3/55-7/63 . # 211 609 237B
T-2 Brk Shoes Ft. 8/63-7/70 . # 211 609 237D
T-2 Brk Shoes Rear 3/55-7/63 . # 211 609 537B
T-2 Brk Shoes Rear 8/63-7/70 . # 211 609 537E
T-2 Brk Shoes Rear 8/70-7/72 . # 211 609 537J
T-2 Brk Shoes Rear 8/72-73 . # 211 609 533B
T-2 Brk Shoes Rear 8/72-79 . # 211 609 537N
T-3 Rear Brake Shoe
T-3 Brk Shoes Rear 8/63-74 . # 311 609 537D
Disc Brake Pads & Buggy Rear
Brk Pads Buggy rear Disc, fits Varga 311 615 107/8 calipers
........ 2 3/16" x 2 1/16" . # 311 698 151
Brk Pads T-1&Ghia up-72 . # 111 698 151A
Brk Pads SB & Ghia 8/72-79 . # 111 698 151B
Brk Pads T-2 8/70-7/72 . # 211 698 151D
Brk Pads T-2 8/72-7/79 . # 211 698 151C
Brk Pads T-3 8/65-7/71 . # 311 698 151
Brk Pads T-3&4 8/71-73 . # 311 698 151C
Brake Hoses
9.25" . Rear 68-on IRS . #113 611 775E
10.8" . Rear (FF) Rear IRS . #211 611 775B
12.75" . Front SB (FF) 74-79 . #113 611 701E
13.5" . Front 67-78 w/disk Brk. & T3 67-73 . #311 611 701B
14.5" . Front 8/66-78 (not SB) . #113 611 701D
17" . Front 56-66 . #211 611 701
18.5" . Front 60-64 . #113 611 701
Metal Brake Lines "Metric"
6.5" . Brk. Line 165mm . # 113611735F
7.375" . Brk. Line L/Front >-7/66 . # 113611723A
7.5" . Brk. Line L/Rear T to Hose SA . # 113611763A
10.25" . Brk. Line 260mm . # 113611736D
12" . Brk. Line "T" to Hose 71-79 SB . # 113611723J
13" . Brk. Line 338mm . # 113611781D
15" . Brk. Line 381mm . Rear SA outer . # 113611782
21.5" . Brk. Line Rear "T" 69-78 . # 113611764C
25.5" . Brk. Line "T" to Hose SA . # 113611764B
31.5" . Brk. Line 800mm . # 113611724J
64" . Brk. Line 1642mm . # 171611739
7 ft . Brk. Line 2174mm . MC to Rear "T" # 311611741
Brake Master Cylinders
Buggy & T2 up to 7/66 # 211611011J $19.95 Note: this one uses the screw in reservoirs
Note: All MC below must use stock reservoir tubing (has no threads for reservoir).
T-1 Master Cyl. up to 7/64 # 113611021.
T-1 Master Cyl. 8/64-7/66 # 113611023B
T-1 Master Cyl. 8/66-78 except SB # 113611015BD
T-1 SB Master Cyl. 8/70-8/79 # 113611015BH
T-2 Master Cyl. w/servo 8/67-7/79 # 211611021AA
T-2 Master Cyl. 8/69-7/70 # 211611021T
T-3 Master Cyl. 8/66-8/73 # 311611015J
Brake Reservoirs & Misc Parts
Brake Reservoir . T-1 & SB 67-on . # 113 611 301L
Brake Reservoir for T-2 60-67 Metal Base # 211 611 3011
Brake Reservoir Cap for #2 . # 113 611 351
Bleeder Valves T-1,2,3,4 . # 211 611 477
Bleeder Dust Caps "Rubber" . # 211 611 483
Brake line "T" Metric . # 803 611 755
Brake Switch 2-prong . # 113 945 515H
Brake Switch 3-prong . # 113 945 515G
Emergency Brake Cables & Spring Kits
T-1 . E-Brake Cables
# 113 609 721F Brake Cable 8/57-12/64 1742mm/68.6"
# 113 609 721L Brake Cable 1/65-7/67 1779mm/70"
# 113 609 721J Brake Cable AT 8/68-7/72 1810mm/71"
# 113 609 721M Brake Cable MT 8/67-7/72 1773mm/69.8"
# 133 609 721 Brake Cable 8/72-8/79 1749mm/68.8"
T-2 . E-Brake Cables
# 211 609 721L T2 wo/servo Cable 3/68-8/71 3435mm/135.2"
# 211 609 721P T2 w/servo Cable 8/69-7/71 3435mm/135.4"
# 211 609 721T T2 Brake Cable 8/71-7/79 2960mm/116.5"
Brake Shoe Retaining Kit
Consists of 2 springs, 2 pins, 2 retainers (requires 2-kits per wheel)
# 311 698 071 Front - std 65-78 & Rear 68-79 . Ghia Rear, 68-74
. . . . Thing F/R 73-74
# 211 698 072 T-2 Brk. Shoe retainers 64-on 1 5/8" long Pin
Drum Brake Hardware Kits
# 113 698 301 Hardware Kit for 2 Wheels Front 58-64
# 113 698 162 Hardware Kit for 2 Wheels Front 65-79
# 113 698 003 Hardware Kit for 2 Wheels Rear 58-79
Rear Brake Drums
Rear 4-Lug Brake Drum
4-Lug Brake Drums are about 9 1/8" I.D. with 2.5" spine length and use the 1 3/32" wide brake shoes.
# 113 501 615J
5-Lug Brake Drums
Used up to 1968. Drum I.D.=9 1/8" with axle spline length of 1 7/8", Brake shoe used is 1 3/32" wide. The 5-Lug Bolt Pattern is 205mm. # 113 501 615D
5-Lug "VW Thing" Rear Drum
Easy way to use 5-lug wheels instead of the stock 4-lug as used on 68 and later T-1
The VW Thing uses same Backing Plates & Brk Shoes as 68-on T-1. Plus increase tread width approximately 1 1/8".
Drum I.D.= 9 1/8" dia. and uses the 1 3/32" wide brake Shoe. The axle spline length is 2.5" long.# 181 501 615A
T-3 Rear Brake Drum
It is Larger in Diameter and uses Wider brake Shoes then the T-1 or Thing. It also uses larger wheel cylinder then the T-1. Often used to upgrade the rear drum brakes. Brake Drum is 9 13/16" dia. & uses the 1 3/4" wide Shoe. Axle spline length is 2.5" long.# 311 501 615E
131 721 163 . Brake Pedal Return Spring
113 609 163A . Backing Plate Plugs
113 609 205A . Brake Adjusting Stars
113 609 209 . Brake Adjusting Screws
211 611 477A . Brake Bleeder Screw Valves
211 611 483 . Brake Bleeder Screw Dirt Caps
311 721 173 . Brake & Clutch Pedal Rubber Pedal Pads.
Return to “VW's For Newbies”
Who is online
Users browsing this forum: No registered users and 1 guest
