What Do You Want To Know About Your VW?
Moderator: david58
Locked
Post by david58 » Sat Mar 08, 2008 2:45 pm
Welcome to the best Volkswagen site on the Internet. The Shoptalk Forums is about being a VW family orientated site. Please read the rules. I am just an old guy here that is gathering information on these little old air-cooled German Cars, and Buses. The content we add to this site will have great growth potential for the STF. The objective here is to make this The Best VW Internet Information Center. Thanks guys for all the help. And Welcome to the STF. :wink:
A Good Place To Start If You Are New
Indepth Exploded Views of Major Components
Engine Overhaul & Specifications
How to Work on Your Volkswagen Videos
Heater Channel Replacement Videos
How to Videos Installing Type 1 Cooling Tin by volkaholic1
VW Books, Manuals, and Literature
PDF File Library
ENGINE RELATED INFORMATION
How to do Proper Maintenance
How the Engine Oiling System Works
How to Cool the Engine
How to Tell the Differences in Timing Marks on Pulleys
How to Tell Which Belt Fits
How to Find Top Dead Center
How to Adjust and TroubleShoot your Stock Carb by Jim Thompson
How the Fuel System Works
How to Remove the Fuel Line from Inside the Tunnel
How the Ignition System Works
How to CC your Heads
How to Tell Correct Engine Bolts Dimensions
How to Tell Which Engine Gasket To Use?
Carb Identification & Specs
Correct use of a dial indicator
TRANSMISSION RELATED INFORMATION
How to Tell the Differences in CV Joints and Axles
How to tell the Differences in Clutches
How to Tell the Differences in Flywheels
How to Tell the Differences in Pressure Plate and Throwout Bearings
How to Tell the Differences in Transmissions Used in VW's
How to Adjust Your Shifter
Transmission CODE Location
How to tell if your trans is for T4 or T1 motors
SUSPENSION RELATED INFORMATION
How to Narrow Your Front Beam by spotfreerynse
How to Replace Ball Joints
How to Lower Your Bug
How to Set preload on rear torsion springs
How to Shim the Link Pin Front End
How to Tell the Differences in Wheel Bearings
How to do a 4 to 5 Lug Drums Conversion
How the Brake System Works
A Break Down Of the Front Suspension Parts
Brake Part Numbers
Removing Fuel Line from the Tunnel Loaded with New Pics
How To make a Adjustable Narrowed Beam
ELECTRICAL RELATED INFORMATION
What Do You Know About Wiring?
Type 1 Wiring Diagrams - PIX Thread
Type 1 Wiring Diagrams in Download-able PDF
Testing the Ignition System No Spark
MISCELLANEOUS INFORMATION
How to do a Body Swap with Pics
How to Decode Your VIN Numbers
How to get Replacement Keys
How to Rebuild your 56 to 61 fuel reserve tap
Re: New Sticky
Post by david58 » Sat Oct 17, 2009 6:55 am
If anyone has any info that needs to be added to the Sticky PM me.
Re: What Do You Want To Know About Your VW?
Post by david58 » Tue Feb 08, 2011 7:26 pm
These links have been added to the stickies note they are uncontrolled off site links.
http://www.midsouthvw.com/TechTips/TechMain.html
http://www.superbeetles.com/Tech_talk/jan.htm
Post by david58 » Tue May 24, 2011 6:10 am
Anyone that has info that should be added to this sticky PM me.
Post by david58 » Mon Nov 07, 2011 8:20 am
Post by david58 » Mon Nov 07, 2011 1:21 pm
How to replace a frame head..............
http://www.shoptalkforums.com/viewtopic ... 8&t=137805
Post by david58 » Thu Nov 10, 2011 2:41 pm
turboblue wrote:
BlueBus wrote:What is the difference between a type1 1600 starter and a type2 2000 starter?
Type 1 manual transmission starter:
And while we are on starters, T 1 autostick starter:
Type 2 091 starter:
Post by david58 » Tue Nov 15, 2011 2:53 pm
Post by david58 » Thu Nov 17, 2011 8:51 am
Post by david58 » Tue Jan 17, 2012 6:17 am
david58 wrote:
derluftwagen wrote:Since i always just scribble notes on small sheets of paper just to loose them and remeasure, I decided to make some worksheets that I can keep for future reference and to give to customers when I complete a build.
martyrg wrote:I put together an engine build worksheet a couple of years ago. It lists wear limits, torque specs, places to write down rod bolt stretch, crank end play, etc, etc. Is is very comprehensive but I'm sure you'll think of more! It is in Excel format. Everett agreed to host it here: http://www.thesamba.com/vw/archives/inf ... _sheet.php
Take a look and modify as you see fit!
Marty
http://www.aircooledtech.com/parts_list/
Post by david58 » Sun Jun 10, 2012 6:51 pm
louis123 wrote:Dont know if this has been posted before.
A video of how is a turbo made.
Saw this on tv this morning and thought i should share.
They seem to balance the internals at 100 000rpm :shock:
Locked
