VW 28 pict 1, 1974 VW Beetle
Moderators: david58, Daniel G
KyDale
Post by KyDale » Fri Dec 09, 2016 10:54 am
Need 12 volt choke Thermo.
Sent from my XT1650 using Tapatalk
KyDale
Re: VW 28 pict 1, 1974 VW Beetle
Post by KyDale » Mon Feb 13, 2017 10:52 am
Want to buy VW Pict 1 Carburetor for 1974 VW beetle 12 volt DC.
KyDale
Post by KyDale » Mon Feb 13, 2017 10:54 am
Correction want buy Carburetor Choke 12 volt for
1974 VW Super Beetle 28 Pict 1.
dragvw2180
Post by dragvw2180 » Mon Feb 13, 2017 12:07 pm
I am no expert on every carb but I believe the Super came with a 34 PICT-3 until they went FI , wasn't the 28 on some single ports ?
sideshow
Post by sideshow » Mon Feb 13, 2017 10:42 pm
Most 28 Pict era carbs have choke holes that only fit 6 volt choke elements.
Maybe you should post a picture of what you have?
KyDale
Post by KyDale » Thu May 25, 2017 4:20 pm
[soundcloud][/photo 28 Pict 1
Single port choke.soundcloud]
KyDale
KyDale
Post by KyDale » Sun May 28, 2017 8:10 pm
Yes 28pict 1 single port. The element is broken. I need the element
KyDale
KyDale
Post by KyDale » Sun May 28, 2017 8:11 pm
I tried upload pic but can't. It has 3 screw holes mounting
KyDale
dragvw2180
Post by dragvw2180 » Mon May 29, 2017 9:07 am
Why not put the correct carb on your 74 Beetle , a 34pict3 , if you have a dual port 1600 ?
KyDale
Post by KyDale » Mon May 29, 2017 12:05 pm
Single Port
Post by Marc » Sun Jun 04, 2017 2:29 pm
28PICT and PICT-1 were for 1200cc Beetle engines. 30PICT-1 came on 1300 and 1500 (the `67 version has a power fuel system, earlier ones don't). 30PICT-2 were on `68/`69 1500 - VW's first attempt at an "emissions" carb, and not one I'd recommend. The last small-flange stock carb was the 30PICT-3 on the 1970 1600SP.
Any of the 30PICTs would be better unless your engine's a 1200. With the stranded accelerator cable of the `74 I'd recommend staying with a late 30PICT-1 or newer which has the self-contained return spring (adding that to an earlier carb results in poor geometry which can cause it to stick at wide-open-throttle).
The "large-diameter" choke element will fit any Type I carb from 28PICT-1 through 34PICT-4, it's not a rare item.
Try to avoid the early style with a ceramic shell and a single rivet attaching the terminal, the newer ones in a metal case with two rivets are more durable. 113 129 191G
KyDale
Post by KyDale » Sun Jun 04, 2017 5:29 pm
Ceramic what I have.
