my turbo engine
Moderator: Type 4 Unleashed
jonas_linder
Post by jonas_linder » Mon Mar 27, 2006 4:49 pm
func412 wrote:
dstar5000 wrote:
func412 wrote:
Does the type 1 HD dual springs fit to Type 4?
No.......that would be too EASY!
Don
Ok, what to do then? Do I have to machine the heads for different springs or....
I didn´t find any topics of that issue :oops:
Csp-shop.de says
HD dual springs for type1 or type4.. no different part number :?
MattKab
Post by MattKab » Mon Mar 27, 2006 6:45 pm
'Relatively HD springs that require no maching, on 'some other head' ? :?
1979 Karmann Beetle with 1.8ti T4 (still pastel yellow)
1970 411 Variant (black) daily driver
1964 lil' window Beetle (soon to be black)
dstar5000
Post by dstar5000 » Tue Mar 28, 2006 9:02 am
They are not concerned that you have to machine the heads.....
They assume that YOU know what you are doing.
:wink:
Get a friend's T1 HD dual springs and try to install them on your head....
WITHOUT machining..........
:lol:
Don
jonas_linder
Post by jonas_linder » Tue Mar 28, 2006 11:41 am
I'm sure he meant if it COULD be used ;)
dstar5000
Post by dstar5000 » Tue Mar 28, 2006 11:52 am
func412 wrote: Does the type 1 HD dual springs fit to Type 4?
I'm like a computer, VERY STUPID!
:lol:
I only deal with the details........
:wink:
Don
nasse
Post by nasse » Thu Mar 30, 2006 1:12 pm
starting on the cooling tinn.
did some sandblasting before I start welding the stuff.
here's the tool I use to trace shapes, that and cardboard makes it quite easy
almost done:
MattKab
Post by MattKab » Thu Mar 30, 2006 4:34 pm
I'm using that exact same profiling tool for my tinware!!! The secret weapon is out...I didn't use it there tho' :wink:
One thing for you to consider at this early stage is to make allowances for any changes in the distance between the heads, as in head fly-cut/cylinder shimming as needed, later down the road, to get your CR where you want it. The tins will be very stiff, when finished.
The blasted steel looks great!!!
I hope to have most of my cooling in black paint this weekend, that will be a milestone :) It's almost smooth enough.
Matt
jonas_linder
Post by jonas_linder » Thu Mar 30, 2006 4:48 pm
Damn that tool is cheating :lol:
Looks great! ;)
Keep the pictures coming :)
MattKab
Post by MattKab » Thu Mar 30, 2006 5:00 pm
jonas_linder wrote:Damn that tool is cheating :lol:
Too right, go grab yourself one!, mine was a pound from a poundshop :D
jonas_linder
Post by jonas_linder » Thu Mar 30, 2006 5:07 pm
I work at a hardware store :roll: :wink:
MattKab
Post by MattKab » Thu Mar 30, 2006 5:31 pm
Well you don't need to buy one then, you could put it back when you're done :wink:
I might be asking you for CAD files soon :)
Can Drive Soon
Post by Can Drive Soon » Thu Mar 30, 2006 5:39 pm
MattKab wrote: Mine was a pound from a poundshop :D
LOL, the british dollar store! :P
My dad has one of those for his carpentry work.
nasse
Post by nasse » Fri Mar 31, 2006 12:48 pm
did a temporary mockup today. so I can start to figure out how to route
the runners from turbo etc.
starting to look like a motor don't it :)
jonas_linder
Post by jonas_linder » Fri Mar 31, 2006 3:19 pm
Looks great! I would suggest changing that bend after the exhausthousing! It is very restrictive if it's the original saab!
nasse
Post by nasse » Fri Mar 31, 2006 3:42 pm
jonas_linder wrote:Looks great! I would suggest changing that bend after the exhausthousing! It is very restrictive if it's the original saab!
thanks Jonas, yes it's the original Saab
do you know if its possible to cut the flange of that bend and migweld a new bend to it?.
