Turbo type4 fastback:)
Moderator: Type 4 Unleashed
Mark the canuck
Post by Mark the canuck » Thu Nov 10, 2005 2:27 pm
Thanks! very cool 8)
jonas n
Post by jonas n » Thu Nov 10, 2005 2:57 pm
thanks for the kind words guys! :)
To start with,the 1/8 time was with 10 years old tires;) the wheels stopped spinning first in third gear :shock: I bought new TOYO tires after that but i didn´t get the chanse to test them on the strip...
I´ll see if i have some more pics...
And to Sandeep! go for it,we want to see your type 4 turbo soon! :D
Ephry73
Post by Ephry73 » Thu Nov 10, 2005 4:35 pm
That should do it(the tires) Hey, how did you make the engine support bar?
Ephry
racelook
Post by racelook » Thu Nov 10, 2005 5:38 pm
Jonas-en...
I just love your work and hearing from your experiences!!!
Keep us informed
Good luck Wiebrand
Wally
Post by Wally » Fri Nov 11, 2005 2:27 am
jonas_linder wrote:just klick "Nästa"
Yes, it is Nasty for sure! :lol:
Jonas,
What did you do to the flywheel/crank connection that survived your 'side-stepping' :shock: ? If it let a 091 bus trans let go before your flywheel bolts snap at 345 Nm, they must be quite "sufficient" :lol:
Very curieus what you plan to do for upgrades. Keep us informed!
Thanks,
Walter
jonas n
Post by jonas n » Fri Nov 11, 2005 3:12 pm
The engine support bar is made from 20x20x2mm square tubing.... bolts to the original mounts on the engine,with urethane bushings at the outer sides. I was at the garage today to take some pics but the camera battery died :( The flywheel is mounted with the original bolts! just torqued a little bit more :wink:
The planned upgrades for the engine is new cyliderheads,I dropped one seat from the ones i have now and had to make an oversize seat that i dont like... I was thinking about 42x40 heads what do you guys think about that? And i really have to remove the headgaskets,i cant remember how many times i had to change them this summer.... A new cam is also on the list,any suggestions? :wink: i want it to rev more!! right now it´s just alot of low rpm gearboxkilling torque! And i really have to get rid of the wheelhops :?
Of course i´ll keep you informed about my work,i just have to do something in the garage,not just sit there and drink coffe :wink:
right now im taking apart the heads..removing rusty exhaust bolts and the valveseats and guides...
Hope someone understands my english :D
/Jonas
Ephry73
Post by Ephry73 » Fri Nov 11, 2005 3:52 pm
Sweet! are those urethane mounts from what application? the 42X40 sizes will favor more a turbo application than a N/A one.
Ephry
jonas n
Post by jonas n » Fri Nov 11, 2005 4:19 pm
the urethane mounts is the inner one for the front control arm on the McPhearson bug;)these ones i think..
http://www.aircooled.net/new-bin/viewpr ... 04&cartid=
Wally
Post by Wally » Sat Nov 12, 2005 10:07 am
Well, your english is fine :wink:
I would really upgrade to the B.A.S. 12.9 flywheel bolts and have him machine the flywheel holes accordingly, before 'accidents' happen... :roll:
How much lift does your current cam have? Is it a specific model/make you have now? 270 duration doesn't mean that much, as I don't know at what valve lift your duration has been measured...
What size throttle body have you used now?
Tnx,
Walter
Ephry73
Post by Ephry73 » Sat Nov 12, 2005 10:47 am
Sweet! Jonas, that is a good way to use the urethane bushings. I may look at that for a fiend's type 3 mount. Thanks for sharing.
Ephry
jonas_linder
Post by jonas_linder » Sat Nov 12, 2005 9:56 pm
sharing is fun!!!
Jonas is my teatcher(spelling??!? :D ) ;)
jonas n
Post by jonas n » Sun Nov 13, 2005 1:15 pm
The lift is 10,71mm... dont know how the duration it´s measured....
the throttlebody is som ford junk i got from Jonas Linder for a burger :wink: i´ll measure it some day.......
Some pics of the enginesupprot..
It bolts rigt on the original mounts...
took a picture of the adaptor for the type3 air intake.
jonas_linder
Post by jonas_linder » Sun Nov 13, 2005 1:24 pm
your engine looks so much more professional then mine do :?
jonas n
Post by jonas n » Sun Nov 13, 2005 1:29 pm
I think it just looks oily and dirty :wink:
Ephry73
Post by Ephry73 » Sun Nov 13, 2005 1:40 pm
It is purely gorgeous. Functional, used and works! cannot ask for more. I definitely like the design of that mount. in square aluminum it should be the ticket for most apps.
Great Job Jonas
Ephry
