Pauter Ratio rockers
- Tony Z
Anyone have the joy of using the pauter 1.4 or 1.6:1 ratio roller tip rockers?? What is the verdict on these for a street racer / weekend warrior??? Even better, will they stand up to daily driving??
I built a 2.6 liter porsche engine, it has a pauter cam, crank rods, and the rockers you were talking about. It has 103mm JE forged pistons for the 78mm crank. The rokers were sold with the cam, they have a sheet together telling the lift, duration, cold lash and all the specs for them . This sheet was made to cover the ratio of the rocker and the grind of the cam itself. The answer to the question, They work very well, Be carefull not to break the adjusting screws by binding them and trying to tighten them, I used a set of lash caps too to widen the rolling area.
