I Need Feedback On A Product I'll Be Producing
Moderator: Type 4 Unleashed
cal 67
Post by cal 67 » Wed Apr 04, 2018 3:13 pm
I've been working on a run of economy chamber volume measuring tools and deck height measuring tools for the Type 4 crowd. The chamber tools consist of standard plexiglass plates in the 90mm, 93-96mm, and 103-106.5mm bore sizes, and a plastic 50cc syringe. The deck height tool is a solid 1" surface plate-flattened steel bar with a 2" travel dial indicator installed in the center. It uses a set screw to hold the indicator in-place. The kit will include the appropriate standoffs to compensate for the stud protrusion. My price point at this time for the entire kit is around $70.
How do you think the community will respond to these tools?
Is this a real problem for home builders without access to machinery?
Would this be perceived as a luxury item, or a necessary tool?
Are there any features that I should incorporate into these kits?
What are non-machinists currently using?
I'd love to read any concerns and/or responses. Thanks all!
Clatter
Re: I Need Feedback On A Product I'll Be Producing
Post by Clatter » Wed Apr 04, 2018 4:15 pm
Hi,
A couple of thoughts, FWIW..
I already have an indicator, and they are available cheaply. Most do.
Some even use feeler blades..
1" is pretty thick. Those type 1 ones are 1/2" IIRC?
A luxury item, yes..
Even so, I'll buy one! :-)
What's that Noise??
cgates30
Post by cgates30 » Wed Apr 04, 2018 11:16 pm
I created my own tools when rebuilding my engine, but everything was kind of "put together" as needed. With that said, a kit would be nice.
cal 67
Post by cal 67 » Thu Apr 05, 2018 3:17 pm
Thanks guys. I'd love to read more replies.
Regarding your comment Clatter, I purchased a Type 1 deck height kit years back; the common 4-stud plate with the cutout and set screw for ballpark measurements. When I would run my feelers around the bore, the areas fathest away from the center would always be tighter than the middle. That 1/2" steel plate was actually flexing when I would torque-down the four head nuts to spec.
So I use a two bolt steel bar instead. No more issues. The dial indicator is just an economy Chinese one; good enough within less than a thou. It also serves as a tool to check timing mark accuracy.
patto
Post by patto » Fri Apr 13, 2018 6:31 pm
For $70 i'd buy a kit for sure, great to see some type 4 specific tools coming out.
GARRICK.CLARK
Post by GARRICK.CLARK » Sun Apr 15, 2018 10:21 am
A tool I would buy for type 4 engine rebuilds is something that holds a pair of cylinders down at the same time so that I can put a straight edge across the cylinder sealing edge to see if the cylinders are sitting at the exact same height.
Lo Cash John
Post by Lo Cash John » Mon Apr 16, 2018 2:59 pm
Put me down for one.
Email me at:
JHunt
AT
ConleyTelco.Com
I'm sure you can figure that email out. I did it that way to reduce spam-bots finding it.
