I'm continuing to put together a full-house 2270 built around a real exhaust and whatnot.
Should be making 200HP or more, if goes as planned.
This means it will be getting an upgraded clutch..
It uses a 914 flywheel -215mm "Porche type", not Bus.
The P-car world seems to have a few different kits,
All of which are $600+
https://www.pelicanparts.com/catalog/Su ... .htm#item0
The Type4Store seems to offer a 6-puck disk as the solution?
https://type4store.com/products/clutch- ... -disc.html
Kennedy sells a 215 P-Spec Stage 1 for $310, reportedly good to 230 ft./lbs. or so.
Also saw someone (Wally?) with some Sachs 'Super Duty'(?) P/P somewhere once?
Who has crossed this bridge and lived to tell the tale?
Would like to do this only once, since it's all to be balanced as a unit..
Thanks!
