stock rod length and pin height type 4 2.0
Moderator: Type 4 Unleashed
Paul H
Post by Paul H » Wed Feb 07, 2018 4:38 am
Anyone know what the rod length and pin height is on a stock type 4 2.0 motor ? A friend is fitting a 78.4mm DPR crank so we need to figure out what the best T1 rod and piston combo is
Real parts=Real Performance-Get Real
Opinion is the medium between knowledge and ignorance (Plato).
TZepeSH
Re: stock rod length and pin height type 4 2.0
Post by TZepeSH » Wed Feb 07, 2018 5:01 am
Rod length: 131mm, pin height 36mm.
wreck
Post by wreck » Wed Feb 07, 2018 5:03 am
!31mm rod length , stock 2 lt pin height is 36mm .
Paul H
Post by Paul H » Wed Feb 07, 2018 5:33 am
Wow an instaneous response :D
So using readily available 137mm type 1 rod and a 35mm pin height Type 1 94mm piston we need spacers of about 10mm which
will cause pushrod tube troubles
wreck
Post by wreck » Wed Feb 07, 2018 6:20 am
AA pistons have a forged 96mm kit with a 30.08mm pin height . also Porsche length rods 135mm . heaps of options using Type 1 rods . I've just finished a 103 X 78 using 30.08 pin height and 135mm rods . no clearance issues and still using the standard pushrod tubes .
Paul H
Post by Paul H » Wed Feb 07, 2018 11:18 am
I'll have a look at those but I try to avoid 2618 race type slipper skirt pistons. The Keith Black hypereutectics seem to have disappeared
Type 4 Unleashed
Post by Type 4 Unleashed » Sun Feb 11, 2018 3:28 am
Hi Paul
The source for Keith Black Hypereutectic pistons is EMW.
Richard
EMW
