Speedi-sleeve---part# for t4 flywheel seal?
Moderator: Type 4 Unleashed
Post by Piledriver » Fri Jul 21, 2017 3:59 am
Have a good flex plate but a pretty deep groove in the seal surface...
Anyone know the part# offhand for a speedi-sleeve for a T4 flywheel seal surface repair?
(if not I'll post it up once I figure it out)
Udo Airbus
Re: Speedi-sleeve---part# for t4 flywheel seal?
Post by Udo Airbus » Fri Jul 21, 2017 7:07 am
I think you need to check whats availible at a webshop, and do some measurements:
Example: http://www.aandrijfshop.nl/skf-speedi-s ... ore=en&p=1
Good Idea, I need this for my caravan bearings :D
VW T1 1964 - Mouse Grey - Pearl White OG paint
Bagged, Porsche steeringrack/brakes..IRS, AMR Supercharged 1600 (sold) building a 1971cc EFI turbo/supercharged engine
Post by Piledriver » Fri Jul 21, 2017 11:46 am
Can't seem to find a "new" or even worn seal surface spec in the Vanagon Bentley manual, need to know that as you can turn them down a little at least once to fix this, and going an extra .010" may cause issues if still original OD. I'll have to check a few flywheels later today to get a comparison...
Bruce.m
Post by Bruce.m » Mon Jul 24, 2017 5:01 am
I like the SKF speedi sleeve. Need to slit the flange before fitting so it can be removed afterwards (twists off in a coil).
