T4 Tear Down / Rebuild in Jax FL
Moderator: Type 4 Unleashed
analogtherapy
Re: T4 Tear Down / Rebuild in Jax FL
Post by analogtherapy » Mon Aug 14, 2017 5:13 pm
Clatter wrote:
Mon Aug 14, 2017 3:11 pm
MMmmmMMMmm, That's some nice looking stuff all clean like that.
Love them lifter bore sleeves..
Did you ever have your crank/flywheel/pressure plate/fan spin-balanced as an assembly?
That's worth doing for sure, when you have everything apart like this..
Don't forget to check your oil pump out,
And make sure your timing mark is er, marked accurately.
FWIW, I have never had any luck whatsoever getting paint or powder or polish or anything to stick to a mag fan shroud long term.
Thanks Clatter! I feel like I've cleaned cleaned and more cleaned! I would like to add a tip for anyone who might not know: I wanted to make sure the oil galleys were clear of metal debris, so I took both case halves outside and used a garden hose to flush them out. Sure enough, there were several pieces of metal chips/flakes that were large enough to make me glad for flushing them :shock:
Oh, and yep, got the whole assembly balanced. Crank/flywheel/pressure plate/fan, and bolts. And rods and pistons balanced.
So, question...
I just got both case halves mated, with a thin coat of Permatex form a gasket. I put my flywheel on so I could more easily rotate the crankshaft to check for any binding. So....how easily should it turn? Mine turns, and doesn't feel like it's binding. But it does feel tighter than it did when turning it prior to both case halves being on it (which sounds completely reasonable, but...I'm just a bit paranoid at the moment).
analogtherapy
Post by analogtherapy » Mon Aug 14, 2017 7:09 pm
I'll add this: In Jake Raby's video he turns his using the rotor on the distributor. Mine won't do that.
I can turn it using just the fan hub. It's not what I would call an "easy" turn, but I can turn it with one hand.
I'm pretty sure that I seated the bearing dowels correctly. I took photos at the time showing the front and rear main bearings seated as far as they could go. If these were seated correctly, I would think that both of the two other bearings were seated correctly as well (or the case itself wouldn't seal correctly/cleanly). Is that a reasonable conclusion?
FYI: The crank journals only got a polish, and the bearings are STD inners, .020 outer. Case received an align bore of .020.
Last edited by analogtherapy on Thu Apr 26, 2018 11:28 am, edited 1 time in total.
analogtherapy
Post by analogtherapy » Tue Aug 15, 2017 3:24 pm
Update: I removed all case hardware, and separated the halves.
I noticed some faults right off the bat.
1) I had applied a bit too much form-a-gasket near the cam plug, and some had worked its way into the closest cam bearing.
2) The No 1 main bearing seemed a bit sluggish to turn by hand. It's possible that some of the form-a-gasket worked it's way into it as well. I'll clean it up, and give it a fresh coat of lube. BTW, I'm using Ultra Slick Engine Lube.
3) I think this may be the real issue: I had a local shop press on the crankshaft gears. When they did this, they put the No 3 main bearing on, and used white grease. I thought the white grease was too thick, and it made the bearing a bit harder to spin compared to the others. So I poured a bit of Ultra Slick into the bearing. But it seems to have made it tackier, because just trying to spin that bearing is noticeably more difficult than the others.
So, is there any way to flush the white grease out, and start fresh without having to have the shop pull the gears and remove the bearing? If not, I guess I'll be making another trip there.
sideshow
Post by sideshow » Tue Aug 15, 2017 10:49 pm
White grease is not a bad choice, a classic in the industry. Any of the aftermarket super-ultra-bling-lube I notice to have a high film strength, I see no harm in minor amounts being used. Unless it is going into storage, plain oil works fine on the crank.
Any aerosol spray oil will flush a lot of it out, marvels mystery is a favorite of mine. But why?
And no signs of "new" dowel pin dents typically means it seated ok, but look to make sure after the line bore that the case side of the hole is deep enough to prevent pinching.
Clatter
Post by Clatter » Thu Aug 17, 2017 1:18 am
I'm kind of a nut for these things,
But with the bearings available today, you can never be too sure.
Main bearing tolerances these days are VERY suspect!
Don't think it's like the old days where you just install them..!
I put just the cam in, and torque the case bolts, and check (wack) it for end play and free turning all by itself.
Also put the crank in the bearings, no rods or cam, and check that way.
Obviously, with no glue, and also with just a bit of light oil.
I'd be blasting away all the white grease and lube you used with carb cleaner and compressed air.
(Not that there's anything wrong with white grease or the stuff you used)
You just want to get good feel.
Again, light oil..
Dowel pins can be too long,
The dowel pin hole in the bearing can be too shallow,
And, like 'Sideshow' said, the line-bore can make your pin holes shallow in the case.
So, be sure to check for a 'witness mark' where the pin might be pinching..
You might see it as a shiny, or silver spot on the bearing where it rides on the crank journal..
I even like to check the spin of the crank with the main case bolts at 5 or10 ft. lbs. or some other light number,
And make sure it's the same, or very close, to how it feels torqued to spec..
The mains are the hardest thing to get perfect now that bearing tolerances have gone to China junk random specs.
You might also consider using a plastigauge on the center main?
Also make sure the two halves of the center main are not proud of the case parting line.
Look and feel with a straightedge..
Torque the case halves with just the main shells in place.
look at the parting line to make sure the halves aren't being held apart.
It will look like the spread center main in the pic in my cheap junk build.
Have had to shave the ends of the center main shells at the parting line lately - sand the ends of the shells on wet/dry because they were too big/long..
Bearings can totally suck and blow sometimes nowadays.
Make very very sure you are not getting handed a steaming pile of 3rd world garbage disguised as bearings!
- Doug Ellsworth
TZepeSH
Post by TZepeSH » Thu Aug 17, 2017 1:34 am
How did you get that engine case so clean? I washed mine in the dishwasher and it is nowhere near so clean. I like your work!
analogtherapy
Post by analogtherapy » Thu Aug 17, 2017 1:01 pm
OK, thanks sideshow! Will do.
analogtherapy
Post by analogtherapy » Thu Aug 17, 2017 1:03 pm
Again, light oil..
Lot's of good suggestions. Thanks Clatter. I'll be giving it another go in the next couple of days, and will report back.
analogtherapy
Post by analogtherapy » Thu Aug 17, 2017 1:08 pm
Haha! Thanks! Yea this was a multi-stage cleaning. Pre-machine work, it was 1) engine de-greaser and a scrub brush. 2) pressure washer. Then the machine shop gave it a bath, and after that, it got a run in the house dishwasher. :D
analogtherapy
Post by analogtherapy » Thu Sep 28, 2017 9:51 am
Well, after a few test mockups, I believe I may have determined the reason for the tight rotation of the crank I was experiencing after partial assembly (cases bolted together): tight fitting cam bearings. After fitting, and turning the crank/cam over multiple times by hand, shiny polished spots can be seen on the cam bearings. When placing the cam into the thrust side of the case (case open) the cam spins freely. When joining both case halves and only lightly tightening the 6 through bolts by hand, the cam is noticeably tighter and does not spin freely.
Here are shots of the problem bearings (the ones with the larger polished areas):
My question is: what's the best way to go about smoothing these out and getting a better fit? I've read that using a small amount of fine lapping compound in the bearing saddles, and then spinning the cam and allowing the cam to do the work is one way. Using emory cloth by hand is another.
Thoughts?
Last edited by analogtherapy on Thu Apr 26, 2018 11:29 am, edited 1 time in total.
Lo Cash John
Post by Lo Cash John » Thu Sep 28, 2017 10:59 am
Just for kicks, have you thought about trying a different set of bearings first? Always try to replace or modify the part which is disposable or cheapest to replace should you F-up.
Post by Piledriver » Thu Sep 28, 2017 8:59 pm
I'd also take a mic to the cam and see where the issue lies.
Is there any dirt or corrosion behind the bearings?
Was the block welded to fix the oil pickup bolt "syndrome"?
Is there any evidence that someone partially pooched it ala same "syndrome?
analogtherapy
Post by analogtherapy » Fri Sep 29, 2017 8:00 am
Hey man! Yea, I've ordered a different brand of bearings, just waiting on them to arrive at this point.
analogtherapy
Post by analogtherapy » Fri Sep 29, 2017 8:01 am
No dirt, and no visible evidence of a T4 syndrome fix.
Clatter
Post by Clatter » Sat Sep 30, 2017 9:24 am
If a different set of bearings doesn't do the trick..
(make sure they are different - lots of places sell the same stuff).
You can open the bearings up on the ID slightly with fine steel wool.
More common is oversized cam journals, as was said before.
Have seen people take a thou or two off of the cam OD a couple of times now.
Use different grits of emery cloth for this - easier on a lathe for sure.
Take it down close to size with rougher grits, then polish to a fine shine.
See why this is so much harder to do now?
Used to be that you just put these together!
Now, you have to check, and often adjust, everything.
- Doug Ellsworth
