End play approximation
- bad62bug
Re: End play approximation
the shims don't go in between the flywheel and crank, they go around the crank between the flywheel and bearing
Ahhhhh thank you! Now I get it. I don't have any shins on hand so I didn't understand how the fit. I'll order them now.
- bad62bug
Good luck try to use 3 shims if possible
There is a gap betwen the crank thrust and flywheel thrust surfaces you can easily measure if its standing on a workbench bolted together, with no bearings/shims.(with the right tools)
The bearing and the shims fill that gap, minus a little bit of oil clearance.
BTW, That's the other way to figure out the required shims.
No case needed.
No case needed.
Wow thanks. That would be clever and makes sense now. I appreciate everyone's input. I think it's really cleared up the patchwork of threads on endplay. VERY helpful for the beginner like me.
