hi are type 4 alloy pushrods
strong enough for dual springs .
or should i use aftermarket chromemolly pushrods
type 4 alloy pushrods with dual springs
Re: type 4 alloy pushrods with dual springs
Damo I'd have thought that they'd be strong enough , I'd guess most change them because they're heavy .aircooled net have a selection of heavy duty alloy push rods and info on what spring pressures/rpm . I don't like chromoly because they are noisy . I went with heavy duty ACnet alloy pushrods . I'm getting the my heads set up with beehive singles , I didn't like the idea of removing so much of the guide post to fit duals and wanted to experiment with something else.
- Lo Cash John
What beehive singles are you installing? Any details would be appreciated.
The plan is to run PAC 1286's , the installed height is a lot higher at 1.75 but that gives me 600 thou lift without reducing guides or guide posts , custom length valves and spacers on the rocker posts etc ,I'm not looking forward to setting up the rocker geometry.
The heads(new amc's) are getting the seats (46/40) and plug relocation done at the moment , I'll port them then give them back to the guy doing the valves/machine work to sort out
It will be a while before they get completed but I'll post some pics of the engine build when it goes together , 103x78 , web 277
The cam is a little wild but was to cheap to pass. I'm running TS lifters so if it's to much cam I can always change it .
