Set up for upright cooling only.
2056cc, 71 stroke, 96 bore, 10:1 comp.
H beam rods, total seal rings, Web-cam(494), Scat lube a lobe lifters
JE lightweight wrist pins, Scat deep sump, 914 windage tray, Modified Berg
oil pump cover [has custom 125 psi relief valve built in], Modified Berg achiever pulley, Jaycee pushrods, solid rocker spacers, 1.7 rockers, chromoly rocker studs, dual valve springs and retainers, Manley spring cups, 44mm intake valves, 38mm exhaust valves, CB magnaspark ignition system, Treuhaft valve covers and intakes.
Bench run for 30 minutes, built by 30 years experience VW air cooled only Mechanic and great guy in Va named Mark Wilson.
$2000
Call or text Matt 267 767 4565
